    A personal WIP.
    29 Posts 7 Posters 5.1k Views 7 Watching
      No plans means a lot of this guesswork is gone over time and again. Changing one dimension means changing those around it and I am finding this a frustrating process.
      Bleep and try again I suppose.
        I am uncertain on a method to reproduce these window perlins in the picture. There is no real close up I can get that is any sharper than this streetview image and all I can remember is they are fern type plants. Considering they come from 1870 or so they are not in bad condition but methodology would be helpful. Thanks.
          I assume you mean the 'capitals' on the 'stone pillars' between the windows...
          A purlin is beam supporting roof rafters ?
          A perlin is a kind of noise ??
          Make the capital as a simple 3d component, with just a few changes of plane - you don't need to model every 'petal' or 'leaf'.
          Add a textured material mapped onto it - made from an image cut out from the photo.
          You probably need two components and two textures - one for the square ones at the door/widow-sides and another for the angled ones between the windows...
            Yes that is what I mean. Sorry not aux fais with the architectural terms. Thanks for the advice/help.
            • tademaT Offline
              tadema
              Hello Mike, have you tried the local planning department? usually they have "recent" submitted applications filed electronically (here in H/pool) since 2005, you may be lucky. Also different areas often had the same house design or slightly altered, an attic ect give that a try.
              Without plans your best option is brick counting πŸ˜„ it's my favourite pass-time. Below is a skp. file of the brick bond and gauge guides to reference to, this is how I always start. I notice that the scale of the door reveals and frame width are a little "out", these should help.
              That kettle of boiling water sure brings back memories of the good old "care free" days πŸ‘
              John
              Mike.skp
                Thanks John, been to the various planning departments and there have been no mods to the huse that would require planning permission. The original method was to remove the plans and replace that with a certificate once permission had been granted and there are no 'plans' extant anywhere. I tried the brick counting thing but must have got an error as 12' 2" is a bit much for a ground floor, even for those times. What I did was get the stairs right on the three levels which gives a height of 10 feet for the ceilings at the front and 7 feet for the ceilings at the back of the house which fits with the only experts I know, like those who lived there longest. My mum resided there from 1934 right up to 1969 when the family was forced to move. The bricks in the model are probably right out but I have been more concerned at the moment with things like stair and ceiling height and the windows. 6 foot high windows? weird in my mind.
                • tademaT Offline
                  tadema
                  Hello Mike, Here's a quick model of the house. Please check the dimensions as it's as accurate as time allows ATM. The bricks don't help as they don't show the joints off very well! The width of the bay window is my main concern. I'll have a better look tonight, it's something to work off.
                  John
                  Mike House.skp
                    Thanks John, already modified the bay as it was too deep. The side windows are only about a foot wide. I have a lot of groups to adjust separately as I go along.
                      John. I have sent you a PM.
                      • tademaT Offline
                        tadema
                        Hello Mike, I tried to reply (am) but it's saying your blocking IM's πŸ˜† .
                        John
                          Not that I know of John but then I dare not mess with forum settings as I would probably end up living in the arctic circle. I will have a look and see if there is anything afoot and mouth, as in one in t'other.
                            Thanks for the heads up, I would not never have known otherwise. Sorted now.
                              As a sideshow and to get away from altering dimensions which I seem to be doing in my sleep at the moment, I am producing a cook range as would have been used in the early parts of the 20th century. The house will be showing different rooms at different times so here is a wip of the cooking range. Only an amalgamation of different styles found on the internet but this was a house for working class people so the decoration would have been toned down or missing altogether. I know my grandmother used a tool like this as late as the 1950's.
                              Hobson's choice oven range.
                              • daleD Offline
                                dale
                                That electric meter is a steam punk as it gets....
                                Mike if you feel like a challenge and decide to try modeling the capitals, here's a link to a very old post by Simon le bon (Simon,where are you?) that could help.
                                I'll be following this interesting project.
                                http://sketchucation.com/forums/viewtopic.php?p=62185#p62185
                                  Thanks Dale, I'll look that up.
                                  Place the range in the chimney breast and placed some utensils too.
                                  In place.
                                    Pretty much as far as the range oven will go for now. There might be a few tweeks but not until the final stages.
                                    Range oven in kitchen.
                                    • Bryan KB Offline
                                      Looking good!
                                        Ta mate.
                                          Making all the furniture from scratch so this might take a while. A radiogram/phonogram which my mother would recognise as similar to the unit owned by her parents.
                                          Radiogram/phonogram WIP
                                            Almost finished the radiogram with turntable and radio. Visualizer render.
                                            One texture for emphasis.
