    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
      pankaj_tamore
      Dear Mr.Pierreden,
      Thank you very much for this incredibly magical plugin some i had in my mind for long time for making creeper in desired way but unfortunately i have encountered problem in using this plugin smoothly. please guide to fix the problem.problem i experienced i explained in attached PDF file please go through the same.
      Thanks & regards
      Pankaj T
      IVY Problem report on 21.11.14.pdf
      • KrisidiousK Offline
        Krisidious
        @pankaj_tamore said:
        Dear Mr.Pierreden,
        Thanks & regards
        Pankaj T
        Read this guide and see if that doesn't help you.
        http://www.sketchup-house-plans.com/Live-Ivy-Settings-Guide.zip
        By: Kristoff Rand
          @kris
          can we get this up as a tut on the site?
          the file is a winner
            Krisidious
            Absolutely... How do you want it?
            By: Kristoff Rand
              however you want it to appear.
              of course article will heavily incorporate schema tags and author info box for you so feel free to go wild
                Krisidious
                I don't know if I'm the author or not... I did a lot of testing and made some tuts for this plugin back in the day, but can't remember if I did this or if someone else gave it to me.
                Regardless, it's a great resource and I'll bring it out of SU and put in a better format.
                By: Kristoff Rand
                  Krisidious
                  Driven has pointed out to me that one of the textures on the file belongs to a "Gordon"... Anyone remember someone named Gordon?
                  Well, Gordon... Wherever you are... We'll credit you with this resource.
                  By: Kristoff Rand
                    driven
                    Search is a wonderful tool
                    [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:1fdzrjgt]Gordy_Z[/anchor:1fdzrjgt]
                      [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:26ycz78i]Gordy_Z[/anchor:26ycz78i]
                      He's been inactive for the best part of two years ?
                        Krisidious
                        Because someone's name is Gordy they are the same Gordon we are looking for? Gordon is the name of the user on their computer... Don't know if it would be the user on the SCF board. Doesn't ring any bells for me. But, who knows... Could be him.
                        I did a search on the 17-18 pages on this thread and didn't find any mention of a Gordon.
                        By: Kristoff Rand
                          Krisidious
                          Rich, I sent all of those guide/experiments to you in a PM. You might want to hit them will spell check. and just use find/replace to change the directory for all the images.
                          By: Kristoff Rand
                            chris87
                            Sketchup 8 pro error !!!
                              ... and what happens when you click on 'continue' ?
                              The sliders/ivyleaf icons depend on that lib...
                              That js error is from one of the standard jquery code libraries - it's relating to 'msie'.
                              What version of Internet Explorer do you have ?
                              Try updating it...
                                Krisidious
                                Here's the Gordon we were looking for. Thanks to Driven for hunting him down.
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=450#p460919
                                By: Kristoff Rand
                                  chris87
                                  Try updating it...
                                  IE9
                                    But IE11 is current, although IE9 ought to be πŸ˜• OK
                                      Krisidious
                                      Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
                                      Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
                                      Here it is.
                                      http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
                                      Here's what it contains.
                                      By: Kristoff Rand
                                        Thanks Kris πŸ˜„
                                        Remember to use a SKP as a custom leaf you must name it 'ivyleaf_XXXXX.skp' and put it in the ..Plugins//LiveIvy/Textures subfolder.
                                        The 'XXXXX' can be any text you want [e.g. 'Kris'] - I recommend using something logical - although you will see a thumbnail to click on !
                                        I also recommend that you consider editing the SKPs to 'hide' some outer edges etc, which will improve the appearance of the 'leaves' etc ...
                                          Krisidious
                                          Roger that... I did the 1-10 on the old one but Rich came behind and redid them. So I wanted to touch base with all of you first.
                                          Do you think we should keep the norms and bumps etc? I take it that's for render monkeys.
                                          By: Kristoff Rand
                                            chris87
                                            I installed iE 11
                                            The same problem occurs !!!
                                            • 11
                                            • 36
                                            • 37
                                            • 9 / 37
