    [Plugin] ShadowProjector
    129 Posts 36 Posters 112.7k Views 36 Watching
      @gonvaz said:
      I'm afraid I can't make it work. I select a face, then I click tools>ShadowProjector, select lines, or faces, etc. and nothing happens. I haven't been able to get any projection of any shadow.
      Any error messages if done with the Ruby Console open ? Can you post a simple example SKP etc...
        Gonvaz
        I've been trying to make it work with the attached example.
        Sometimes I get "You must preselect at least ONE suitably oriented face!".
        When I get no message, I see no projections.
        shp example
          @Gonvaz
          I am baffled what you are trying to do πŸ˜•
          This tool projects shadows from objects [essentially faces in the model/groups/components] onto preselected faces in the current context.
          The SKP you attached seems to contain no faces whatsoever, so that is an immediate problem!
          Your 'pyramid' form is only edges, and whilst you can get edges to cast real-shadows, this tool only considers shadows from faces.
          So, it should work given the right inputs - but I suggest you really need to reread and understand the tool's instructions... and then ask it to do what it's capable of, and you will get results.
          πŸ˜’
            Gonvaz
            I'm really sorry, TIG! I attached a wrong SKP. 😳
            Now I have attached the one I was using to test the plugin.
            And I have found why I couldn't make it work: some of the faces were reversed.
            I just selected the faces, right-click the selection and click "Reverse Faces".
            It works perfectly!
            1s.skp
            • plot-parisP Offline
              plot-paris
              Hey TIG, just to let you know. The plugin produces a bug-splat with SketchUp 2013
                It doesn't with me πŸ˜•
                Works just fine...
                Do you have an example of a failing SKP you can provide?
                Does it work in v8 but not in v13 ?
                Do you also have other plugins loading that might conflict ?
                More info please... πŸ˜’
                  plot-paris
                  Ok, I did a bit of testing:
                  • I got the plugin to work with SU 2013
                  • I found that the new default character in the scene - Derrick - is causing the Bug Splat
                  • I created a dynamic component with a hidden-toggle element myself. Everything worked fine...
                  • I also created a component with fixed size. Worked fine too...
                  So, no Idea what the problem is. But Derrick is the clue πŸ˜•
                  DerrickFucksItUp.skp
                    Derrick makes a bugsplat in v8 AND v2013 when he's included in a shadow-projection !
                    Even when he's been exploded and hidden objects like the speech-bubble have been erased.
                    I think it's because sadly Derrick contains 26 edges that are <1mm long, and 3 of those are <=0.2mm, with the smallest being only 0.13mm long.
                    We all know [except apparently Trimble πŸ˜’ ] that 'tiny geometry' causes SketchUp several issues.
                    Shadows are 'projected' from the objects' face vertices, and if any two are almost coincident in 2d then SketchUp takes them to be coincident, and then the needed very small edge fails to be replicated in the shadow's outline set in the projection... and then it can't form a loop etc etc... Failure.
                    Also 2d face-me components might also cause problems with shadow-projections because their 'bounds' are shot to pieces by turning to face the camera etc...
                    I'll see if I can get Trimble to fix Derrick for the next maintenance release... πŸ˜’
                    Meanwhile, avoid 2d face-me components like Derrick, in your shadow-projections... until further notice... πŸ˜’
                      plot-paris
                      ah, I see. Yes, usually I don't keep Derrick in my scenes. But unfortunately I did when trying your (very useful) plugin... πŸ˜’
                        max8167
                        Hello,
                        Is it possible to export result (text element : pourcentage, area...) in a .txt or .csv file?
                        Thank you for advance
                          @max8167 said:
                          Hello,
                          Not at the moment.
                          They are not saved with the group as attributes so they are not extractable later on.
                          However, I'll look at adding that functionality to the tool...
                            An updated version, v1.3, is now in the PluginStore http://sketchucation.com/pluginstore?pln=TIG_shadowProjector
                            The 'Shadow' groups now get 'ShadowProjector' attributes covering the areas of their face[s] and shadows, its % and the reported units.
                            To view this select likely 'Shadow' group[s] - with no current selection the whole active context is considered.
                            To see the data, type into the Ruby Console:
                            TIG.shadowReport
                            All of the Shadows groups' attribute data is printed out, formated for copying into another document...
                              max8167
                              Your plugin it's very useful
                              Do you think it is possible to change script in order to have result during a time period and not at a given time? Have you avenues of work and reflection?
                                @max8167 said:
                                Just do several shadows over a series of scenes with different times ?
                                It cannot cope with reflections, if that's what you meant ??
                                  Updated version v1.4 is now available.
                                  It has an additional option that can be typed into the Ruby Console:
                                  TIG.shadowReport **true**
                                  to choose a file and write the shadow report directly into it...
                                    barney_and_ted
                                    Hello TIG,
                                    Your plugin is very useful πŸ‘
                                    The face name is automatically create in the report ! Is it possible to change it ? In order to have more convenient name.
                                    Thank you
                                      djh
                                      Dear TIG,
                                      Your plugin looks like just what I need - to export vector (dwg or dxf) with shadows. I am drawing technical illustrations with fine lines and shadows. When I export them as a jpg or tiff and shrink them down, the lines get broken and don't print well. But, I can't figure out how to use your plugin. I keep getting this message even when I select a face. "You must Pre Select at least ONE Suitably Oriented Face!" I haven' projected a shadow yet. I even tried with some very simple models, but...
                                      Can you please help me?
                                      DJH
                                        driven
                                        make sure the 'face' is the front face...
                                          djh
                                          Thank you very much, Driven and TIG. Also, I exploded all the components and groups. It works wonderfully.
                                            You don't need to explode everything.
                                            But you do need to select the face[s] to receive the shadow outlines.
                                            This means they do need to be in the same context, but then you could edit the container and select the face ?
                                            • 3 / 7
