Import Short Cuts into MAC
How can i import short cuts into mac, either from windows or from another Mac
Thanks -
@agrazdi said:
or from another Mac
Thanksthe shortcuts .plist is in your user library..
(if you're on lion, the user library isn't readily available.. do this:
-click finder in the dock
-click the "Go" menu at the top of the screen
-push the option key
-notice when you hold the option key down, a menu item named Library appears.. this is your user library.. Click on it-- if you're not on lion then just go user/ library
(the rest of this applies to all osx versions)
- go Application Support/ Google SketchUp #/ SketchUp
in the SketchUp folder, you'll see a file namedShortcuts.plist
you can move that file to another mac in the same location and the shortcuts will be available on the new setup
Ready to switch from SU Pro Windows and pay the fee to go SU Pro for MAc. I have about 50 custom keyboard shortcuts on Win version. Seems impossible to import them from Win to Mac or am I missing something?
Thanks, Ron -
I'm trying to import my Preferences.dat file from windows into my mac. Anyone know how?
Hey
I've recently upgraded my iMac to Mavricks, and I can't find my shortcuts.plist in the above mentioned folder. In fact I cant find it anywhere. Any ideas. Thanks!
@baruch t said:
.... Any ideas. Thanks!
try setting a new shortcut, using 'Preferences'...
then have a look in your "User/Library" path to see if SU has made it...
some of the folders aren't made until requested or altered...
Thank you John
Ive recently purchased a PC and was wondering if there is any way to transfer my shortcuts from a mac to a PC?
Baruch -
@baruch t said:
...any way to transfer my shortcuts from a mac to a PC?
not that I'm aware of, they are stored in very different formats...
john -
A couple of years ago I wrote the attached Ruby to import shortcuts to Mac from Windows. Read the comments at the top of the file for instructions on how to run it and how to recover if it borks. As the comments state, this is experimental code. It worked for me, but I can not guarantee that it will not cause any issues in your specific case.
Steve
!steve
you could add the.gsub(/[Pp]lugins/, "Extensions") if v15in there as well...
just a thought
john -
@driven said:
!steve
just a thought
johnGood point. I hadn't run this on 2015 as yet...
and what about going the other direction...
i.e good to bad, oops mac to windows...
I'll leave that exercise to one of the fallen...
