    Import Short Cuts into MAC
    13 Posts 7 Posters 3.8k Views 7 Watching
      agrazdi
      How can i import short cuts into mac, either from windows or from another Mac
      • jeff hammondJ Offline
        @agrazdi said:
        or from another Mac
        the shortcuts .plist is in your user library..
        (if you're on lion, the user library isn't readily available.. do this:
        -click finder in the dock
        -click the "Go" menu at the top of the screen
        -push the option key
        -notice when you hold the option key down, a menu item named Library appears.. this is your user library.. Click on it
        -- if you're not on lion then just go user/ library
        (the rest of this applies to all osx versions)
        • go Application Support/ Google SketchUp #/ SketchUp
        in the SketchUp folder, you'll see a file namedShortcuts.plist
        you can move that file to another mac in the same location and the shortcuts will be available on the new setup
          RCD
          Ready to switch from SU Pro Windows and pay the fee to go SU Pro for MAc. I have about 50 custom keyboard shortcuts on Win version. Seems impossible to import them from Win to Mac or am I missing something?
          Thanks, Ron
            cmac14
            I'm trying to import my Preferences.dat file from windows into my mac. Anyone know how?
              Baruch T
              Hey
              I've recently upgraded my iMac to Mavricks, and I can't find my shortcuts.plist in the above mentioned folder. In fact I cant find it anywhere. Any ideas. Thanks!
                driven
                @baruch t said:
                .... Any ideas. Thanks!
                try setting a new shortcut, using 'Preferences'...
                then have a look in your "User/Library" path to see if SU has made it...
                some of the folders aren't made until requested or altered...
                  Baruch T
                  Thank you John
                  Ive recently purchased a PC and was wondering if there is any way to transfer my shortcuts from a mac to a PC?
                  Baruch
                    driven
                    @baruch t said:
                    ...any way to transfer my shortcuts from a mac to a PC?
                    not that I'm aware of, they are stored in very different formats...
                      slbaumgartner
                      A couple of years ago I wrote the attached Ruby to import shortcuts to Mac from Windows. Read the comments at the top of the file for instructions on how to run it and how to recover if it borks. As the comments state, this is experimental code. It worked for me, but I can not guarantee that it will not cause any issues in your specific case.
                      Steve
                      importprefs.rb
                        driven
                        !steve
                        you could add the
                        .gsub(/[Pp]lugins/, "Extensions") if v15
                        in there as well...
                        just a thought
                          slbaumgartner
                          @driven said:
                          !steve
                          you could add the
                          in there as well...
                          just a thought
                          Good point. I hadn't run this on 2015 as yet...
                            driven
                            and what about going the other direction...
                            i.e good to bad, oops mac to windows...
                              slbaumgartner
                              I'll leave that exercise to one of the fallen... 🤣
