    [Plugin] CleanUp
    974 Posts 217 Posters 861.5k Views 217 Watching
      mac1
      zhenning:
      I have used MeshLab to decimate models and found it is best to limit the number of actions taken to one at a time and the sequence can also affect the out come. I have not used ThomThom's plugin but, trying to limit the number of corrections to few at a time may help you keep it a solid. In addition using Tig's solid solver has quite often helped after cleanup. What analyzer are you using one of the 3d printers?
        mac1
        zhenning:
        Arg forgot ๐Ÿ˜ฒ
        http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
        • Z Offline
          zhenning
          @cotty said:
          And the question is?
          The cleanup seems to delete wrong faces? The coplanar error appears only after the cleanup plugin is used to clean the model.
          • Z Offline
            zhenning
            Attached is the file:
            Dropbox
            (www.dropbox.com)
            After some trials, the errors happens when i tried merge faces ๐Ÿ˜ž
              mac1
              Initial application of cleanup does a good job of fixing errors, then running TIG's solid solver had problems to the point of destroying model. That just haapens some times.
              After cleanup suggest you save the file as a stl you can then use one of the free apps some 3 d printers have and attempt to fix the model. The attached jpg shows my results using NetFab more work need to be done. Shapeway had a free service where they would run your model thru there app and possibly fix model. Sadly I have lost link and will have to look for it. Here is info I have
              And the link on use of the app. It free version so does not give full capability
                mac1
                Found 1 link http://www.shapeways.com/tutorials/how_to_use_meshlab_and_netfabb.
                Since Su has a STL export plugin you do not need to use MESHLAB
                  mac1
                  Link 2 http://www.netfabb.com/news.php?nid=16
                  • Z Offline
                    zhenning
                    Found the cause of it. Actually its from the stl ๐Ÿ˜ž I have used netfabb to try to fix it. So, the CFace errors are those extra surfaces added from netfabb to make the model water tight. Then only i imported into sketchup and try to clean it. I managed to solve it by importing the stl directly, clean using cleanup, redraw uneven and erroneous faces. No problem after that. Thanks for the replies mac1
                    ๐Ÿ˜
                    • TIGT Online
                      @lersince1991 said:
                      Is Cleanup working in SKU 2015? Doesn't seem to be appearing in the extensions tab at all?
                      Did you also install the latest Lib for thomthom's tools ?
                      He updated everything to suit v2015 a few weeks ago...
                        Lersince1991
                        Edit: Sorry it is working! (I thought I had restarted ketchup but I hadn't)
                          Lersince1991
                          Edited:
                          Sorry for alerting you!
                          I'm now using the sketchucation extension manager which is a god send for keeping everything up to date and installing quickly!
                            TRIPOD
                            I use SU 2015 x64 Portable. First starting SU was correct with plugins. Next start SU appear errors loading cleanup. TT Lib (latest version) had already installed with extension manager but SU says that it not install. Screenshot below. What is it? Why CleanUp is not loading.
                            http://i67.fastpic.ru/big/2014/1125/98/191fa7fbdbc9dd68ea1d99dae96a8c98.jpg
                              Jim
                              What is "Portable" SketchUp? Where did you get it? Whatever it is, it is not a supported installation.
                                TRIPOD
                                It is the same as "usually" SketchUp is, but does not require standart installation. It very easy if you are often re-install windows OS.
                                It gave me my friend.
                                Why? The way of file system is the same as SketchUp standard installation ones. Other plugins successfully loading into portable version.
                                  kyleboyd
                                  Thom Thom et. all,
                                  I recently got a new computer (Mac running 10.9) and Sketchup 2015 and I am experiencing some odd issues. When I click Clean and run through the dialog box, many coplanar faces are not removed). When I then just click on the Merge Faces button, they are picked up. It seems to be fairly erratic though.
                                  Your help would be greatly appreciated, as CleanUp has been extremely useful over the years and is one of my most used plug-ins (and a large tool in my workflow). Thanks so much for all your awesome work!
                                    Do you have a sample model to reproduce this?
                                      bracisig
                                      hey mate i added the EX but i cant find it in my sketchup dont know what to do ?
                                      • TIGT Online
                                        Assuming you mean EXtension, how did you 'add it'.
                                        Did you install it from the RBZ archive ?
                                        Did you also install the 'TT_Lib' RBZ required by thomthom's tools ?
                                        Both available in the PluhginStore...
                                        http://sketchucation.com/pluginstore?pln=TT_Lib
                                        http://sketchucation.com/pluginstore?pln=tt_cleanup
                                        Did you restart SketchUp ?
                                        Did you read the tool's instructions ?
                                        http://sketchucation.com/forums/viewtopic.php?p=193587#p193587
                                        Is its Extension activated in the relevant section of the 'Preferences' dialog ?
                                        Did you look under the 'Plugins' menu submenu for its items [remember that this is now renamed 'Extensions' in v2015 !]
                                          kyleboyd
                                          Fortunately for me, unfortunately for debugging, I can't seem to reproduce my previous issues.
                                          In trying, I triple checked my cleaning settings, so perhaps I was just boneheaded and it was all user error. (I thought I went through and checked-unchecked the different settings, but maybe not).
                                          Anyhow, thanks for the response, if it happens again, I will be sure to attach the offending sample of model. Thanks again for all your awesome work!
                                            Why this is not cleaning! ๐Ÿ˜ฎ
                                            Works by hand line by line!
                                            noclean.skp
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 48
                                            • 49
                                            • 40 / 49
