    How to correctly set photomatch camera with real exif ?
    renderpluginsextensions
    16 Posts 4 Posters 2.8k Views 4 Watching
    • L
      Lummoxcz
      @jiminy-billy-bob said:
      Disable both "Override FOV" and "Override focal length", and leave the zoom factor to 1. It should work fine.
      Hi, I've tried it and result isn't correct - see attachement.. 😞
      • andybotA
        andybot
        @lummoxcz said:
        When I finally corectly matched my model with inserted photo in SU, I can´t set my camera with the same parameters as picture was shooted.
        When I use on photomatch scene a tool "Creates a physycal camere with real world camera parameters", I'll see that focal lenght should be 26mm but when I use it in VRay camera setting, my render looks different than in viewport...
        any distortions in photomatch won't be matched by vray. One thing you can try is to click on the zoom tool. Then look at the focal length value in the VCB (box at the bottom right of your SU window) click in that box and type in the exact same number. You may see the camera "jump" slightly, with the photomatch distortion being removed. Then save your new view and try rendering again.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          That's odd, do you have a model to share?
          • andybotA
            andybot
            That's been a problem forever. Have you not encountered it?
              rspierenburg
              Not sure if this matters or not, but the Advanced Camera tool output on the first image is set to Screen, have you tried setting it to Photography > Full Frame (or APS-C depending on what type of camera took the image).
              • L
                Lummoxcz
                This is maybe misunderstanding becouse of my english.. .)
                There are some distortions which I saw by modeling the room from photomatch - I do not care about (its not so big problem).
                My problem is that: I can see correctly matched model as I want in scene but I can´t render it in the same view as I see in viewport..
                Please see following link to my SU model:
                http://leteckaposta.cz/496483957
                • L
                  Lummoxcz
                  • L
                    Lummoxcz
                    Hi, I have tried it but it didn´t help - as attached
                    Photo was tooked by Digital Canon 7D which isn´t fullframe
                    I also tried to uncheck override settings and to have only advanced camera - the result is quite simmilar as in viewport but still it doesn´t match with enviroment/matched photo.. 😞
                    override setting acc to camera
                    unchecked override settings
                    • L
                      Lummoxcz
                      I do not know if I understood correctly - I typed the same number from VCB box as the new override FOV and notting jumped..
                      When I tried to render it still isn´t correct.
                      • L
                        Lummoxcz
                        so no one knows? 😞
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Sorry but no... I tried with the file you provided, but came to the same conclusion as you, use a 17mm focal length override.
                          • L
                            Lummoxcz
                            thank you for help anyway.. 😄
