    How to correctly set photomatch camera with real exif ?
    renderpluginsextensions
    16 Posts 4 Posters 2.7k Views 4 Watching
      Lummoxcz
      @jiminy-billy-bob said:
      I think Vray mimics a 35mm camera. So you should enter the focal length of your camera only if it's a full frame DSLR (Or an old 35mm film camera). Otherwise you need to convert the focal length to a 35mm equivalent.
      I expected that if I don't override FOV in VRay Camera setting, I should get exact the same view of render as is a viewport.. It means without any special camera settings - Do I wrong?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Disable both "Override FOV" and "Override focal length", and leave the zoom factor to 1. It should work fine.
          Lummoxcz
          Hi, I've tried it and result isn't correct - see attachement.. 😞
          • andybotA Offline
            andybot
            @lummoxcz said:
            When I finally corectly matched my model with inserted photo in SU, I can´t set my camera with the same parameters as picture was shooted.
            When I use on photomatch scene a tool "Creates a physycal camere with real world camera parameters", I'll see that focal lenght should be 26mm but when I use it in VRay camera setting, my render looks different than in viewport...
            any distortions in photomatch won't be matched by vray. One thing you can try is to click on the zoom tool. Then look at the focal length value in the VCB (box at the bottom right of your SU window) click in that box and type in the exact same number. You may see the camera "jump" slightly, with the photomatch distortion being removed. Then save your new view and try rendering again.
              jiminy-billy-bob
              That's odd, do you have a model to share?
              • andybotA Offline
                andybot
                That's been a problem forever. Have you not encountered it?
                  rspierenburg
                  Not sure if this matters or not, but the Advanced Camera tool output on the first image is set to Screen, have you tried setting it to Photography > Full Frame (or APS-C depending on what type of camera took the image).
                    Lummoxcz
                    This is maybe misunderstanding becouse of my english.. .)
                    There are some distortions which I saw by modeling the room from photomatch - I do not care about (its not so big problem).
                    My problem is that: I can see correctly matched model as I want in scene but I can´t render it in the same view as I see in viewport..
                    Please see following link to my SU model:
                    http://leteckaposta.cz/496483957
                      Lummoxcz
                        Lummoxcz
                        Hi, I have tried it but it didn´t help - as attached
                        Photo was tooked by Digital Canon 7D which isn´t fullframe
                        I also tried to uncheck override settings and to have only advanced camera - the result is quite simmilar as in viewport but still it doesn´t match with enviroment/matched photo.. 😞
                        override setting acc to camera
                        unchecked override settings
                          Lummoxcz
                          I do not know if I understood correctly - I typed the same number from VCB box as the new override FOV and notting jumped..
                          When I tried to render it still isn´t correct.
                            Lummoxcz
                            so no one knows? 😞
                              jiminy-billy-bob
                              Sorry but no... I tried with the file you provided, but came to the same conclusion as you, use a 17mm focal length override.
                                Lummoxcz
                                thank you for help anyway.. 😄
