    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.5k Views 170 Watching
      @marqueso said:
      if it isnt working then you probably didnt install it correctly, as said before, download the script and change the .rbz to .zip. then extract all the files/folders and put them into your plugin folder.
      That's poor advice for someone using SU8M2 or later. There's no reason not to use the .rbz extension and Install Extension from Preferences>Extensions.
      • T
        twillm
        TIG,
        Fantastic plugin.
        I was wondering if a pattern could be used rather than solid fill.
        Architectural drafting hatching as used to depict masonry, concrete etc. would be perfect.
          @twillm said:
          TIG,
          Fantastic plugin.
          Make the SectionCut face using the <Default> material, so that it displays the group's material.
          Simply unlock the SectionCutFace group [if it's locked] and apply any textured material onto the group...
          If you want to manipulate a texture - e.g. rotate it - then it must be applied directly onto a face - so in that case edit the group to access the face directly for painting.
          Unfortunately if you create a SectionCutFace so it 'updates', then when you use Remake the SectionCutFace it will revert to the original material.
          You can current also modify the file SectionCutFace_loader.rb and add a new color 'by name' to the dialog's list - that material has to exist in the model to avoid an error...
          COLORS=[ **"Concrete",** ...
          But I'll look at possible modifications to remember the group's material during a 'Remake'...
            Here is update v4.6 http://sketchucation.com/pluginstore?pln=SectionCutFace
            Now if you use the <Default> material for a SectionCutFace and you paint its group [unlocking if necessary], it then shows that material - perhaps textured, like concrete] - then if it is 'Remade' later on that material is still displayed. This is an alternative to manually adding your own new material names into the dialog's list [in the SectionCutFace_loader.rb file] which can be awkward... OR more simply by picking an existing model-material by name from the end of the dialog's list ...
            • T
              twillm
              After installing latest plugin I was able to apply some hatches.
              Refer included pdf.
              This was achieved by unlocking the section cut face group and using the paint bucket.
              Thank you for the assistance.garage section.pdf
                You can obviously open [i.e. edit] an [unlocked] SectionCutFace group and do many thing to it - like adding or removing geometry, using different textured materials on various faces etc...
                This is fine if the SectionCutFace is made initially 'Fixed'.
                BUT be aware that if the SectionCutFace is 'Remade' [because it was initially set up to allow this to happen, either 'On Demand' or automatically] then all of those changes will be lost in the new version of the SectionCutFace that is created.
                The only way to apply a textured material onto a SectionCutFace which will continue after this 'Remaking' is, to either to initially choose a textured material [from the lower part of the Materials' listing] when creating the SectionCutFace, or to make it initially using the <Default> material and then paint a textured material directly onto the [unlocked] SectionCutFace group, which WILL be replicated if its group is 'Remade'.
                  jamenloh
                  Hi TIG ,
                  Thanks for the plugin , I had tried to use it on my SU 2014 Pro with Vray 2 , I couldn't get the render to turn up the cut sections , it just renders the whole enclosed house instead of the cross section .
                  Just some extra info:
                  • I've installed via the Preference>Extension>Install Extension method, works fine and I see it in my context menu and adding a SectionCutFace fills up the hollow parts of the model
                  • I followed the online video, clicked render after the adding the SectionCutFace to the Section Plane but the original enclosed block turns up in render.
                  • My build is Mac , Sketchup 2014 Pro , Vray 2 .
                  I've tried the plugin on a simple cube and it doesn't render the half cut as well ... is there anything I'm doing wrong or is it version incompatibility ?
                  Section Cut Face
                  https://dl.dropboxusercontent.com/u/1917162/Downloadables/Cube with SectionCutFace.png
                  Vray Render
                  https://dl.dropboxusercontent.com/u/1917162/Downloadables/Vray Render.png
                  Looking forward to anyone with some help ?
                  Many thanks in advance!
                    @jamen
                    Only a few 3rd party render applications will render section-cuts: yours doesn't - therefore, although the black section-face is inside the box, you don't get to see it in the render.
                    The solution is to make a copy of your SKP and use a tool like Zorro2 [ http://sketchucation.com/pluginstore?pln=Zorro2 ] to slice the model at the section-plane [make it visible temporarily] - then you can render it and the black section-face will show up, because the rest of the model has been deleted.
                    Remember to work on a copy because this is a destructive cutting and deletion of much of your model !
                    • jujuJ
                      juju
                      Indigo has a feature that would render section cuts.
                      http://www.indigorenderer.com/features/section-planes
                        jamenloh
                        @TIG , awesome thanks ! Works like a charm now that I can remove off . Maybe its just me , it is only when you explained above that I finally understood what Zorro really does. I had a hard time looking at the pictures in the tutorial to be honest. but it works now ! thanks!
                          Maki84
                          Don`t work under sketchup 2015?
                            It works perfectly in SketchUp 2015. What makes you think otherwise?
                              Yes it does !
                              Read and understand its instructions...
                              Firstly, make sure its Extension is activated.
                              Next...
                              Remember that it is context-driven: there is no menu item.
                              Select [highlight] just one SectionPlane.
                              Right-click > Context-menu > Choose-Command[s] > Options-Dialog > OK > Result πŸ˜„
                                Maki84
                                Thanks. I will study it and i'll tell you
                                  Maki84
                                  Yes, it's runs ok!! The pluggin is on Tools menu. Thanks so much.
                                    For those that come after and might read your post: No, it isn't in the Tools menu. It is found in the Context menu as indicated in the description and instructions for use as well as the reply to you from TIG above your posts. And, being in the Context menu, it only shows up when you right click on a section plane.
                                      As Dave says... πŸ˜’
                                      SketchUp's native 'Section' tool is found under the Tools menu [or on the appropriate toolbar[s]].
                                      This places a SectionPlane which cuts sections through objects in the current context...
                                      These have no 'faces' at the cut-plane.
                                      BUT my 'SectionCutFace' tool only appears when one SectionPlane is selected, and then it appears in the right-click context-menu - no where else. Note how the available commands may vary, e.g. if the SectionPlane already has a SectionCutFace and the Updating option was chosen in this tool's settings dialog...
                                      It will add a group of 'faces' at the cut-plane - using the settings you have chosen.
                                      • E
                                        ednewcome
                                        I love this plugin. It has revolutionised my Sketchup use! Many thanks. Ed.
                                          marceloccrestani
                                          Hello guys!
                                          I installed plugin but when I open Sketchup 2015, it shows this message attached
                                          Anyone can help me?
                                            syahreenhishamudin11
                                            hi everyone. i got some problem to install this plugin. actually just wanna ask where to copy this plugin into my sketchup file? thanks
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 28
                                            • 29
                                            • 18 / 29
