    Working drawings in SU
    10 Posts 5 Posters 492 Views 5 Watching
      Ands43
      How are people producing annotated plan views in SU? I'm thinking draw it in SU then export it to Layout as either an SKP or a DWG and dimension and annotate it there. The computer I've been given is a fairly limited imac with 2Gb of RAM, so that might rule out exporting to DWG.
      What are other people doing?
        I've been using SketchUp and LayOut to make woodworking plans for years. No need to export to DWG. I go direct from SU to LO and then do all of my annotations and dimensions in LO. It works just fine for me.
        Actually, exporting to DWG would defeat a key benefit of using SU and LO: that of maintaining a dynamic link from the model to the documentation.
        • pbacotP Offline
          SU exports directly to Layout in a special way. Read up about it on the software website. There's a thread here on Construction Drawings-- in the LayOut forum.
            Ands43
            Cheers guys, I just remembered I used to export from SU to AutoCAD and not the other way around.
              dammerel
              The one problem i have with LO (with mechanical drawings) is showing hidden lines
              Andrew
                Why is that? I frequently need to show hidden lines in the plans that I do. I haven't found any problems doing so with LayOut.
                  dammerel
                  DaveR
                  If you render as vector i understand the hidden lines are removed..im i correct?
                  the back edges are bitmap rendered
                  what/how do you do it?
                  Andrew
                  • bazB Offline
                    baz
                    @dammerel said:
                    DaveR
                    Andrew
                    I'm curious about this as well.
                      Yes. Back edges are not displayed when rendering in Vector in LO. For hidden lines, though, I use LayOut line entities. I just trace the back edges while in Raster or sometimes guidelines laid out in SU. This gives me a whole lot more control over the appearance of those lines than I could get in SU and generally there's not that many lines anyway.
                      On the left in this screen shot is a Raster-rendered view with Back Edges turned on. On the right is the same view rendered in Hybrid to maintain the face shading. The dashed lines were drawn in by tracing the back edges before hybrid rendering.
                      I've got a woodworking plan in the works right now that will use this idea to show joinery. Maybe I'll be able to post a screen shot of it when I have it done.
                      • bazB Offline
                        baz
                        Thanks Dave, I keep forgetting that you can actually 'draw' in LO as well.
