    Make edges worn
    17 Posts 6 Posters 1.3k Views 6 Watching
    • W
      Wurlit
      @box said:
      You are better off using a textured material. Doing full geometry would make the file huge and sluggish.
      That was my first thought too, since my purpose is to export into Unreal engine for real-time rendering. But coming close to the model one would see the difference. I know of other methods a texture can be used for the effect, like parallax mapping, but i've not much of experience. If there was a way of doing it geometrically with SketchUp, i could always do a polygon reduction (together with quad conversion). Maybe i shouldn't be using SU in the first place?
      @tig said:
      Or perhaps think about using a Style with jaggedy edges πŸ˜•
      That was the first thing i did, thinking it would export the model like this as well. Sorry, i should have mentioned from the start i want to use the model in Unreal engine.
        driven
        did you try 'Sandbox Tool' to make an irregular mesh to start with?
        • W
          Wurlit
          Hi, i can't see how would i embed Sandbox in the workflow. I don't want to build a model anew, i want to be able to modify it so i can have two versions of it - the one i've built, and its "eroded" version. I think of an "age" modification method/plug, random inner deformations on the edges of a selected face/model.
          • KrisidiousK
            Krisidious
            Model Scrambler?
            404 Not Found
            (sketchucation.com)
            By: Kristoff Rand
              I'd suggest using Blender to sculpt the hi-poly detail and bake out the maps from that.
              Then on a lo-poly mesh you can shrink-wrap it to the hi-poly object and use the hi-poly texture bakes to trick the effect of added detail.
              • W
                Wurlit
                @krisidious said:
                Model Scrambler?
                Again, it manipulates the faces, not the edges. More or less what the Fractal Terrain does, TIM suggested.
                I feared this would come! Guess i have to mess with Blender after all. It's kind of a love/hate relationship, i know you can do a lot with it and i've seen some great results, if only i could pass the confusing interface. It sounds quite straightforward. One question, just to be sure. I'm after the first example on the image below, the straight lines due to the geometrical structure of the model on the second example is what i want to avoid.
                http://ultraimg.com/images/cylinder.jpg
                  That's displacement giving that result.
                  Which is geometry heavy. There are means to to get close to this but your geometry will need subdivisions
                  • W
                    Wurlit
                    And which is more efficient for real-time rendering, subdivisions and displacement, or sculpting and polygon reduction? I reckon, none of the two methods can be done inside SU, so exporting to Blender is the logical next step.
                      For realtime rendering you need to sculpt at hi-res and then decimate or shrinkwrap down to lo-poly
                      In fact there is no need to sculpt that much if you have a diffuse map to begin with. You need to pull the convex and cavity detail from the diffuse and use that to displace the hi-res mesh.
                      I know I'm using lots of silly terminology but it is all relatively quick to do with free tools.
                      • W
                        Wurlit
                        Thank you. I'll do my research about doing what you suggest. No worries about terminology, it's a necessary evil, and learning the meaning of these terms will prove useful in the long run.
                        And nevertheless, i appreciate all of you for your time responding.
