    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Shapes, torus, dome, etc. Not for 2015?
    15 Posts 5 Posters 742 Views 5 Watching
      CalypsoArt
      So I just looked at shapes the Draw menu and saw that Torus dome etc was not listed. I found the "Shapes" plugin by @Last and auto installed. However, on startup 2015 had several error messages all linked to the plugin. I had to disable it. Any other plugins compatible with 2015 give these tools?
        Jim
        Install the Shapes plugin from the Extension Warehouse.
        The version in the Plugins Store is obsolete.
        • BoxB Offline
          Shapes from the extension warehouse.
          And shapes the up to date version in Plugin store.
            CalypsoArt
            Thanks all. Installing from the extension warehouse worked. I originally installed from the Sketucation Tools plugin store. I assumed they were accessing the same repository.
            • BoxB Offline
              You installed the wrong one. The @last one is very old.
                Jim
                How are people supposed to know which is the right version?
                • BoxB Offline
                  Yes it is a little difficult unless you know, but I have no control of that, I just happen to remember from another thread.
                  • ntxdaveN Offline
                    ntxdave
                    Interesting tool........how do I control where the shape is drawn?
                    • ntxdaveN Offline
                      ntxdave
                      OK - during this process I also installed the old one. Now I want to delete it. From the screen shot below, is the Shapes Tool (highlighted) the one I should uninstall?
                      If so, where do I go to uninstall it. When I look in the plugin folder, I see su_shapes. Is that it?
                      Since they now are changing from plugins to extensions, are they installed in different folders? If so, where are they? I would like to clean this up......
                        The oldie @Last version is a single file name 'shapes.rb'.
                        It's loads as a basic Plugin, NOT an Extension.
                        The newer/superior Sketchup Team's EWH version is an Extension - named 'Shapes Tool'.
                        Its installation is in two parts: the 'su_shapes.rb' file and its 'su_shapes' subfolder containing the main files.
                        So leave the 'su_' stuff alone and find the ancient 'shapes.rb' file [in the Plugins folder] and delete it... [or you could use SketchUcation Uninstaller on it [.rb >>> .rbx] and then it doesn't auto-load OR show up on the Plugins Manager's lists etc...]
                        When SketchUp restarts the 'good' version should load...
                        • ntxdaveN Offline
                          ntxdave
                          Thanks for the reply but I have some interesting ones (all in the plugins folder):
                          • Did not find any file name shapes.rb
                          • There is a su_shapes.rb file and su_shapes folder
                          • There is also a jwm_shapes.rb file and an jwm_shapes folder
                          See the screen captures above and let me know what I should keep and what I should delete πŸ˜„ I think they have created a little bit of confusion with the switch from plugins to extensions.
                          While I like this tool, I see that it could become problematic in that I cannot control where the shape is drawn. The good news is that it is added as a group so it can be easily moved however, there could be a problem in that it is always drawn at the intersection of the axes (do not know the correct term to use) so if another object is already in that position you might have trouble getting to it to move it..........πŸ˜„
                            The 'su_' pair are the standard Shapes set in the Plugins folder, that makes the 'Shapes Tool' Extension.
                            It comes from the EWHouse.
                            It adds a Draw menu submenu '3d Shapes' containing various items to draw parametric solids.
                            The 'jwm_' set is NOT the @Last set which has a single file named 'shapes.rb' in Plugins, so you don't have that installed.
                            The 'jwm_' set is a modified form of the older 'shapes.rb' now made into an Extension by John McClenahan...
                            It is installable from the PluginStore as http://sketchucation.com/pluginstore?pln=jwm_shapes 'SU Draw Parametric Shapes...
                            It is similar to the 'su_' set, it makes a submenu of the same name, but with two extra tools at the end...
                            Cylinder
                            Cone
                            Torus
                            Tube
                            Prism
                            Pyramid
                            Dome
                            Sphere
                            Helix
                            Helical Ramp
                            Helical Ramp with Sides
                            As the two versions' code is set up separately you might expect that they should both be able to coexist.
                            BUT they use the same Extension Name !
                            So when the 'jwm_' version loads first it claims that Extension name ['Shapes Tool'], and then when the 'su_' version is loaded its Extension name has already been activated so it does nothing more !
                            You should see this reflected in the menu items, because the final two 'Helix...' items only appear with 'jw_' loaded...
                            However, unless you want helical ramps etc, the EWHouse 'su_' version is likely to be the more supported version in the future...
                            So I suggest you Uninstall the 'jw_' version of the Plugin...
                            BUT if you think you might need those functions one day - then Disable the 'jw_' Plugin and when needed you can then Disable the 'su_' Plugin version and reLoad the 'jw_' Plugin and restart SketchUp... Remembering to re-Enable the 'su_' version and Disable the 'jw_' version, should wan to swap back ? ...
                            I expect that's "as clear as mud" πŸ˜‰
                            • ntxdaveN Offline
                              ntxdave
                              TIG - Once again thanks for the reply. Actually, I think I understood you. I removed the jwm_ versions. I think the Helix tool by itself is all that is really needed you can always build a profile and use the Follow Me (or use something like the Smustard Profile Builder plugin) to do the ramp stuff.
                              Again, my biggest complaint (if you want to call it that) is that you cannot specify where you want the shape drawn but as I said before, since it is placed in your model as a group it is easy to move.
                                Jim
                                It would not be difficult to change the plugin so that the generated shape automatically attaches to the cursor for placement. The shapes would just need to be created as Components instead of Groups.
                                Maybe make a feature request in the plugin thread or on github.
                                • ntxdaveN Offline
                                  ntxdave
                                  JWM does not think he can do it (I posted in the thread you suggested). I would like the su_ version to be modified. I do not need the extra two features in jwm's version. The "native" one that works in 2015 would be fine for me...........
