    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • P
      Pherim
      With Sketchup 2015 64 bit, some of these tools don't work as they used to in 2013, Extrude lines and Faces along vector both only work when I enter values, but not by just clicking the start and end points.
        Any messages in Ruby Console ?
        I only updated the code for Didier to allow it to load into Ruby 2 ?
        • P
          Pherim
          Push/Pull Faces along Vector:
          Error: #<NoMethodError: undefined methodisEqual' for 4067.422773715575:Length>
          c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2679:in onLButtonDown'
          Extrude Lines along Vector:
          Error: #<NoMethodError: undefined methodisEqual' for 3512.4586235163288:Length>
          c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2869:in onLButtonDown'
          Both errors appear the moment the left mouse button is clicked to set the end point of the vector, but nothing else happens.
            Thanks, that's very helpful.
            Didier's code [ill-advisedly] messes with Float, adding an 'isEqual' method.
            In v2015 the Length class is changed, so the Float messing on is not reflected as it was !
            I'll look at a fix...
              I corrected the issue between Didier's handling of Float & Length in v2015
              The update is in the PluginStore http://sketchucation.com/pluginstore?pln=projections
              • P
                Pherim
                That was fast! Thanks, now it works again.
                  You report was just the kind I like - you explained the problem clearly - so a cause and a fix was pretty obvious...
                  Much better than the, "It doesn't work..." reports 😄
                  • sumasterS
                    sumaster
                    THanks TIG sir . . . . .
                    waiting for 2014 and 2015 update . . . . 😄 😄
                    Thank you,
                    SUmaster
                    • BoxB
                      He did update it for that.
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20140%26amp;start=90#p543502
                      404 Not Found
                      (sketchucation.com)
                      • andybotA
                        andybot
                        Is it just me, or the tool menu does not show up in 2015? I'm trying to add a shortcut to one of the tools, but I can't find the plugin in the list of commands.
                          There was never a 'Projections' submenu in the Tool menu 😕
                          Only a 'Projections' Toolbar.
                          However, please replace this .rb in the Plugins folder, and tell me if it does what you desire.
                          After a SketchUp restart you should now get a Tools 'Projections' submenu, which is equivalent to its Toolbar items...
                          If so, and it's good, AND there is more user support, I'll update the RBZ with it...
                          projection_extension.rb
                          • andybotA
                            andybot
                            Yep, that works. Thanks!!
                            • zooenZ
                              zooen
                              No longer works with Sketchup Pro 2018, it's unfortunate.
                                What makes you think that it no longer works in v2018 ?
                                I just installed its RBZ from the PluginStore... and it works just fine.
                                The last update to this file was for v2015 compatibility, but it will still work in newer versions too...
                                Because it's a pretty old plugin, then it not been 'signed'.
                                But in newer SketchUp versions you simply have to set the Extension Loading Policy to 'Unrestricted' for it to load and run.
                                • zooenZ
                                  zooen
                                  As much for me, it was because I used the French translation that it did not work. I reinstalled the latest version and copied the file fr_projection.rbs in the folder projection and I also copied the file fr_projection_extension.rb in the folder plugins, because I'm curious. Well that's not very orthodox, I agree. I have part of the plugin in french and part in english! but it works properly.
                                  • zooenZ
                                    zooen
                                    Bon au final je le laisse (avec regret!!) en anglais, il est vieux ce plugin mais bien utile. Et je me fends d'une traduction (merci google). 😉
                                    Good in the end, I leave (with regret!) In English, it is old this plugin but very useful.
                                    • E
                                      Einstein
                                      Would it be hard to make it single-step undo? With larger meshes it creates so huge undo stack that I cannot even CTRL+Z so many steps.
                                      Capabilities of this plugin are marvellous but gotta remember to save my model each time before using it.
                                        jipibi92
                                        Hi, I just downloaded and installed Projection in Sketchup Make 2017:
                                        it is declared as unsigned and doesn't appear in the menu bar...
                                        But I can't find where, in SU Make, I can change the Extension Loading policy?
                                        Not found in ShetchUcation Extension Manager !...?
                                        Strange..
                                        Please help.
                                        Thanks.
                                        Ralph
                                        • P
                                          PElgin
                                          Someone needs to update this very useful extension.
                                            What needs to be updated? I'm using it in SketchUp 2021 and it works just fine for me. Your profile says you are still using SketchUp 8. It should certainly work fine in that version, too.
                                            Project Line(s) Perpendicular to Face(s):
                                            • 7 / 8
