    SU make 2014 for Mac install file?
    9 Posts 6 Posters 245 Views 6 Watching
      CalypsoArt
      A friend of mine has Mac OS/SU Pro 2015 incompatibilities. She tells me she purchased a license but they sent one for 2015, which has issues with her version of OSX. Contacting Trimple/SU has been unanswered emails and voice-mail. I suggested installing Make 2014 to keep working till she can get it sorted out. However, I can no longer find a link to the Mac SU Make 2014 install file. Anyone know if this is still available.
      • BoxB Offline
        Here you go
        http://www.sketchup.com/download/all
          slbaumgartner
          Out of curiosity, what version of Mac OS does she have? If it is Yosemite (10.10), your info is actually backward: SU 2014 has issues with fonts under Yosemite, but these were corrected in the SU 2015 release.
            CalypsoArt
            @box said:
            Here you go
            Thanks, but that link does not have Make 2014, only Pro 2014.
              CalypsoArt
              I'm not sure. But isn't Yosemite the latest version? If so, that is her problem, she does not want to update her current OS to Yosemite.
                Tell her to download the pro version of SU2014. After 8 hours of use it'll revert to Make.
                  slbaumgartner
                  You don't have to upgrade to Yosemite to run SU 2015. I am running it fine under Mavericks. Again, the problems are with all versions or SU prior to 2015 under Yosemite, but not with 2015 under older releases of OS X.
                  • jeff hammondJ Offline
                    maybe she's stuck on Lion.
                    i have a mac pro like that.
                      driven
                      seems like she has 10.7 or lower which is not supported on v2015...
                      if the hardware or circumstance forbids an OS update then SU v2014 or lower is the only option...
                      in either case, contact Trimble citing OS incompatibility and ask for a 2014 pro license in exchange...
                      she'll have 12 months to upgrade for free if needs be...
