    Arc convert? From .skp to .dwg
    6 Posts 3 Posters 1.6k Views 3 Watching
    • I Offline
      ibskibskalle
      Hi - here is a tricky one!
      A 2d question:
      Does anyone know how to export a sketchup file to dwg - and here is the tricky part:
      where for ex. a segmented arc in sketchup, in autocad will import as a "real" arc. Is there a kind of arc reader/convereter so the arc from sketchup will look as a smooth arc in auto cad.
      Its a problem I always have when exporting to dwg for CNC. I always end up using a lot of time redrawing circles in autocad, or another cad program.
      I hope you can help me.
      Best
      Allan
      Denmark
      P.s. I have SketchUpPro 2014
        If you export your model as a 2d DWG, then all curves, including arcs/circles become 'segments' of lines in the 'flat' view.
        But if you export the model as a 3d DWG, then any arcs become CAD Arcs, circles CAD Circles etc.
        However you do need to export a '2d' version of the SKP, so there is no 3d volume to confuse the issue...
        So you'll probably need to do some work on a SKP copy first, export no faces etc...
        • I Offline
          ibskibskalle
          Hey Tig
          Thanks a lot - you just saved me for hours of future work!
          And thanks for this forum - a great way of sharing!
          Allan
          So you'll probably need to do some work on a SKP copy first...
            JGA
            TIG,
            I don't have access to ACAD at the moment, but if you export your SKP model to a 3D DWG model, how do you flatten it - or am just a bit dense?
            Regards,
            JGA
            • I Offline
              ibskibskalle
              Hi JGA
              I just tested it - and i worked fine. You don´t do any 3d in you sketchUp file, you just export as normal - top view, parallel projection and export... and now is the difference - you export to 3d dwg. And when you open it - in my case in 2d draftsight, then its a cad arc.
              Best
              Allan
              @jga said:
              TIG,
                JGA
                TIG/Allan,
                Thanks very much for this tip, it works perfectly!
                A note to others - if you export just the edges, arcs & circles will be translated into DWG arcs & circles.
                If you export faces however, they are exported as a segmented polyface mesh.
                Regards,
                JGA
