    [Plugin] Components manager plugin
    156 Posts 15 Posters 55.7k Views 15 Watching
      glro
      @tig said:
      @giro
      try a folder rename?
      MTX_bibliotheque_(non_classee) 💭
      Stick to ye-olde ASCII A-Za-z etc
      thank you for taking the time to answer
      yes, i already have been faced to this accent problem, but the tricky thing is that sometimes it is the source of the problem, and sometimes not
      for example, the first screenshot, the problem is due to the fact that i buit the model on a computer using windows XP, and today i use windows 7; so the link is not "... program files... " anymore but "program files (x86)"
      anyway, i should change the folder name...
      my concern is how to remove the "#1" at the end of the component name
      what i do now is:
      i replace all the "#1" components by another one which is not already used in the model
      i purge the unused components
      i replace the component "not already used in the model by the one without the #1
      it takes some time...
      • inteloideI Offline
        inteloide
        Hello glro !
        Are all your compatibility issues only about accent issue ? If not, please tell me in order to improve my plugin.
        For HTML size, I will have a look soon.
        For your # issue...well the problem is in SU.
        Actually, my plugin when reloading one or more components I :
        1- load the component definition
        2- remove replace old defintion instances by the new definition
        3- remove old definition by purging all the model
        4- rename new definition with the correct name
        So if there is a # when loading the component definition, it will remains after reloading it.
        But I think that what you want is to upload a component definition with a file different from the file used at begining, don't you ? Then in SU (not plugin), by right clicking and choose "reload", SU ask you the file name...then definition without # will be replace by the new definition but still without #
        Do I'm correct or not ?
        If not, I could write you a tiny plugin that do the job automatically...
        Inteloide
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
          glro
          it seems to me that the #1 component issue is related to your component manager plugin; for example:
          i built a model from components in the component folder in june
          in july, i modify some of the components
          in september, i come back to the model and try to add some of the components that have been modified in july: they come with a #1 at the end
          the real solution would be to use your plugin BEFORE i begin to modify the model; i just realize that while i am writing it
          So, if all the components in the model are updated, when i add a new one, it will come without any #
          i am going to try that...
          thank you for trying to find a solution
            Pherim
            In SU2015 64bit this plugin causes a crash when I use RoundCorner inside a component. I haven't tested other SU versions.
              inteloide
              Hello Pherim,
              Please try version 1.14.10 which should solve your issue and let me know.
                Pherim
                Alright, it works again! Thanks!
                • OxerO Offline
                  Oxer
                  I have installed the v1.14.10 on Mac OS X & SU2015 Make and it appears a Load Errors window with this message:
                  Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb Error: #<LoadError: cannot load such file -- BGSketchup/BGSketchup.rb> /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:inrequire'
                  /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require' /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:13:in module:BGSketchup_Composants'
                  /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:5:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                  /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup_Composants.rb:232:in register_extension'
                  /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BGSketchup_Composants.rb:232:in <top (required)>'
                    Have you also installed his necessary 'Lib' ?
                    http://sketchucation.com/pluginstore?pln=BGSketchup_Library
                    • OxerO Offline
                      Oxer
                      No, I haven't installed it, I 'll try to install it.
                      Thanks TIG for the info!
                      • flyer50F Offline
                        flyer50
                        HI
                        I downloaded the file manager component for sketchup ver 1.14.8
                        I use Win 8 Pro 64bit and SU 8 pro
                        During the installation I always get the following three errors.
                        line 38 char 2 permission denied
                        file:///D:/programmi/Sketchup/Plugins/BGSketchup/JQUERY/jquery-1.10.2.js
                        line 19 char 1 permission denied
                        file:///D:/programmi/Sketchup/Plugins/BGSketchup/JQUERY/jquery.contextmenu.r2.js
                        line 193 char 3 Property or method not supported by the object
                        file:///D:/programmi/Sketchup/Plugins/BGSketchup/Composants/Html/treeview.html
                        how can I solve this problem?
                        the program seems to work with many problems but working and is fantastic
                        I have uploaded the localisation file adding the italian version.
                        I have translated the help file too but I can't manage pdf file and I have transformed the 7 pdf pages in 7 single pages in html format .
                        Now I have the 7 page in html and transalted in italian language.
                        how can I trasform it in one only pdf file?
                        ciao
                        • flyer50F Offline
                          flyer50
                          sorry something went wrong
                          this is the file
                          localisation with italian version added
                            inteloide
                            Hello,
                            To Oxer : Next plugin version will integrate a Library presence control, with prompt if not present and an alert if an update of the plugin is available...
                            To TIG : Thank you for your support ;o)
                            To flyer50 : I've seen your mail, I'll work on your issue. Thank you for your work on Italian translation (rb file received) Please send me your file in html, I will create the pdf file.
                            Inteloide
                            • OxerO Offline
                              Oxer
                              Thanks for the info inteloide, I have installed BGSketchup_Library file and the plugin works fine now on SU2014 & SU2015.
                                arquiman5000
                                64bit problem, please update...
                                  inteloide
                                  Hello, Could you please be more precise ?
                                    Pherim
                                    Hey, the new version 2.0 always asks on startup if I want to use my system's language (German), which I don't, and it says in the window that there is a new version available although I have the latest, and then the custom toolbars I built with Toolbar Editor don't load anymore. Last but not least, it doesn't overwrite the old version but that still remains installed and usable, apparently.
                                    Right now I can't use this in its current version with these issues.
                                      inteloide
                                      Hello Pherim,
                                      Sorry that this version doesn't worked as required for you. I'll try to correct this asap.
                                      • always asks on startup if I want to use my system's language
                                        That's strange : do you have a file BGSketchup_Components_manager.ini in your plugin folder ?
                                      • it says in the window that there is a new version available although I have the latest :
                                        It should be solved now
                                      • then the custom toolbars I built with Toolbar Editor don't load anymore.
                                        I tested on my computer, on SU 2014 and 2015 : it works perfectly...
                                      • it doesn't overwrite the old version but that still remains installed and usable, apparently :
                                        Yes, I forgot to tell that previous version should be removed...
                                      Please keep me informed.
                                      Best regards
                                      Inteloide
                                        inteloide
                                        Well, I correct some little things :
                                          Actually, on SU2014, after some use the icon disappeared... On SU2015 it's ok. Also I noticed that due to language change issue, the icon disappear from Toolbar editor because button name is translated in your language. So, when bug for language will be solved, your toolbar will remains.
                                        Inteloide
                                          Pherim
                                          About the toolbars: It's not like they don't work at all, but they are not loaded properly, some are missing a few symbols, others are missing all of them. When I disable this plugin with Sketchucation Plugin manager, they work again.
                                          Oh, and yeah, it's SU 2015.
                                          No, I don't.
                                            inteloide
                                            Hello Pherim,
                                            Thank you for your explainations.
                                            About toolbar editor, I'll contact plugin author to try understand where the issue comes.
                                            About translation issue, if you don't have the ini file, this means that your options are not solved.
                                            Could you make a search for file BGSketchup_Composants.ini (sorry I made a mistake in previous file name) ?
                                            You may find this file in root folder of plugins files : C:\Users*Pherim*\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                                            Or in :
                                            C:\Users*Pherim*\AppData\Local\Temp
                                            If this file doesn't exist, this means that Sketchup don't have permission to modify this folder.
                                            If this file exists, please send it to me (after you change your translation option and close Sketchup).
                                            Thank you
                                            Regards
                                            Inteloide
                                            • 7 / 8
