    Move points to a '3D grid'
    26 Posts 8 Posters 2.7k Views 8 Watching
      Not sure this reduced poly rock is so good ?Cuboidalizer.PNG'Cuboidalizer' is another name idea too... that or 'Discombobulizer' 😲
      • Dan RathbunD Offline
        Dan Rathbun
        Here's a beta version with an inputbox and undo operation...
        It seemed to only change a cubes vertices in the Z axis ??
        module GridSnap
          @@last_tolerance = 0.25.m
          class << self # PROXY CLASS
            def round_point( point, tolerance )
              grid_pt = point.to_a.map { |n|
                b = ( n / tolerance ).to_i * tolerance
                r = n % tolerance
                (r > tolerance / 2) ? b + tolerance ; b
              Geom;;Point3d.new( *grid_pt )
            def test_it
              pt = Geom;;Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
              tolerance = @@last_tolerance
              grid_pt = round_point( pt, tolerance )
              puts "Original; #{pt}"
              puts "Tolerance; #{tolerance}"
              puts "Grid Point; #{grid_pt}"
            def adjust_vertices( tolerance = @@last_tolerance )
              model = Sketchup.active_model
              vertices = []
              # Collect vertices.
              for e in model.active_entities
                vertices << e.vertices if e.is_a?( Sketchup;;Edge )
              vertices.flatten!
              vertices.uniq!
              # Calculate grid adjustments.
              vectors = []
              entities = []
              for vertex in vertices
                pt = vertex.position
                vector = pt.vector_to( grid_pt )
                next unless vector.valid?
                entities << vertex
                vectors << vector
              # Apply transformations
              model.active_entities.transform_by_vectors( entities, vectors )
              puts "#{entities.size} adjusted to grid."
            def menu_command()
              title   = 'Adjust Vertices'
              prompt  = 'Tolerance'
              default = @@last_tolerance
              result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
              if result
                begin
                  Sketchup.active_model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
                  adjust_vertices( result[0] )
                  Sketchup.active_model.commit_operation()
                rescue
                  Sketchup.active_model.abort_operation()
                else
                  @@last_tolerance = result[0]
          end # PROXY CLASS
          #{# RUN ONCE
          unless file_loaded?("GridSnap.rb")
            # Menu Entry;
            UI.menu("Tools").add_item("GridSnap") { menu_command() }
            file_loaded("GridSnap.rb")
          end #}
        end # module
        I'm not here much anymore.
          Should apply to X,Y and Z... Seemed to work correctly in my quick test...
          • daikuD Offline
            daiku
            @dan rathbun said:
            @thomthom said:
            Cubificator?
            Polyhedronizer ?
            Orthogonizer ?
            Orthographizer ?
            OrthograFixer ?
            πŸ˜†
            It's like Autotune for cad! They can make you sound good, even if you can't sing.
            If you are editing digital music, and you need to make the drum beats perfect, you can move the beats to the nearest sixteenth note, or whatever. It's call "quantizing".
            Clark Bremer
            http://www.northernlightstimberframing.com
              Dan Rathbun
              @daiku said:
              It's called "quantizing".
              TRUE !!
              Restriction to discrete values (or multiples thereof,) rather than any values in the set of possibles (real numbers, in this case.)
              So.. the long term:
              Vertex Positional Quantization
              The short form:
              Vertex to Grid
                rossthompson
                Hi guys, I have had a play with Dan's Beta version and for me it works really well. The verticies are adjusted in X,Y and Z directions and the undo function works fine!
                The only slight problem: it adjusts all the geometry in the model, rather than just the active selection. The original module just adjusted the active selection.
                Any ideas?
                Again thanks for the support - this script should be a realy time saver!
                Ross
                  Dan Rathbun
                  Well .. I did not think I changed the context of what Thomas' code did... just tried to wrap the code properly and added the menu_command() method to handle an inputbox.
                  I'll have a look at it.. again.
                  (And it's not really MY edition just because I added the inputbox.. it's still Thomas' thing.)
                    Dan Rathbun
                    OK... added support for a selection. (Pssst! ... there was no selection support from the beginning Ross.)
                    This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
                    I'll leave those choices up to him, and when he releases version 1.0.0, we'll delete these beta versions in this thread and put in a link to the release thread.
                    #  GridSnap.rb
                    #  by Thomas Thomassen
                    #  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                    #  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                    #  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                    #  This utility quantizes the vertex locations, of the current selection,
                    #    of the model, or just the current context, to a 3D grid, whose interval
                    #    can be set via a popup inputbox.
                    #  Revisions;
                    #   0.1.0 ; 2012-03-26 ; by Thomas Thomassen
                    #   initial beta release
                    #   0.2.0 ; 2012-03-26 ; by Dan Rathbun
                    #   + Added menu_command() method for inputbox and undo operation.
                    #   0.3.0 ; 2012-03-28 ; by Dan Rathbun
                    #   + Revised the menu_command() method to pass a selection set to the
                    #       adjust_vertices() method as a 2nd argument.
                    module GridSnap
                            r = n % tolerance
                        def test_it
                        def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
                          vertices = []
                          # determine the context;
                          ents = model.active_entities() if ents.nil?
                          # Collect vertices.
                          for e in ents #model.active_entities
                          vertices.flatten!
                          vertices.uniq!
                          vectors = []
                          entities = []
                            entities << vertex
                            vectors << vector
                        def menu_command()
                          if result
                            begin
                                if model.selection.empty?
                                else
                                  adjust_vertices( result[0], model.selection.to_a() )
                            rescue
                            else
                      end # PROXY CLASS
                      #{# RUN ONCE
                        # Menu Entry;
                      end #}
                    end # module
                    • V Offline
                      VertexMover
                      Is there an easy way to have it go through the Outliner list and open each model group and snap those corners to the grid?
                      What would need changed in the script so that it would snap all visible geometry to the grid, Without having to manually select and open each group?
                        Dan Rathbun
                        It would need to iterate the model's definition list, changing those that have instances.
                        But I'm not sure if it is really safe to change entities collections outside the current context?
                        PM'ing TT
                        • tt_suT Offline
                          tt_su
                          That should be ok. One just need to keep in mind that the current open context apply a transformation that affect 3d points.
                            Dan Rathbun
                            Ok.. but are ya gonna repost under TT_GripSnap or whatever? (I had said we'd remove the code blocks above and replace with Store links when done.)
                              This wasn't something I ever planned to publish. It was just a code snipped posted for anyone to grab.
                              • 2 / 2
