    SketchUp 2015 is 64bit
    302 Posts 74 Posters 45.6k Views 74 Watching
      d12dozr
      @SU team, thanks for a great release. Glad to see Trimble taking the program in a fresh direction.
      http://goo.gl/f7ooYh
      • david_hD Offline
        david_h
        I just got it and installed. I'm really late to the game. .. .again. Any tricks or traps to bringing over my plugins folder from V8?
        (yes. .. I was still on V8 πŸ’š )
        • BoxB Offline
          DON'T copy over old plugins.
          Install the sketchucation plugin and then auto install all new from there.
            Boy! You sure are late to the game. πŸ˜‰ As Box said, don't. Simple as that.
            • david_hD Offline
              david_h
              Yeah. . .I was afraid of that. Darn it. πŸ˜’
              • david_hD Offline
                david_h
                And that is why I didn't upgrade with 13, 14, whatever. I didn't want to slog thru all the plugsin and crap .. .again. Looks like a fun day for me!
                D
                • BoxB Offline
                  With the plugin store you can just work away and install them as you find you need them.
                  • david_hD Offline
                    david_h
                    Yeah. I know. But I'm not good at this. Kinda Ironic for a "Top Sketchucator" n'st-ce pas? πŸ’š
                    • hellnbakH Offline
                      hellnbak
                      Hey, if I can do it, anybody can πŸ˜†
                      And it's really worth the effort!
                      • david_hD Offline
                        david_h
                        So I am doin' the whole "Plugin store Thing"(thanks Rich for the video) I did know that much. But it gives an "Extensions" directory rather than the good ol' plugins tab.
                        what about old but beloved little plugins with .rb extensions.. Can I just move them into the extensions directory? I can't just create a plugins directory it seems. And do i need to re-download and re-isntall my renderers? Podium, twilight, thea. .. etc etc etc? Thanks for the help
                        and the patience. I'm just out of practice. I don't do this much anymore. Version 8 you know. πŸ˜„
                        D
                          driven
                          @david_h said:
                          ... Version 8 you know. πŸ™‚
                          definitely start fresh and download everything new...
                          have fun
                          • BoxB Offline
                            To put it simply,
                            Plugins are now called extensions.
                            Use the Plugin Store from within SU to install whatever plugins you want from there.
                            Use the Extension Warehouse from within SU to install anything you want from there.
                            Any other plugins from elsewhere should be install in the appropriate manner.
                            .rb dropped into the plugin folder.
                            .rbz installed via the preferences/extension window
                            .zip unzipped into the plugin folder
                            .exe via their own installer
                            The default plugin folder can now be found at
                            C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                            Renderers will need to be reinstalled, some don't have updates yet.
                            Some plugins won't work, but most are being updated or there is something similar available.
                            • david_hD Offline
                              david_h
                              Thanks Guys. I appreciate it.
                              D
                              • Chris FullmerC Offline
                                SketchUp 2015 changed the name of the "Plugins" menu to be the "Extensions" menu. No real difference, we're just working towards getting all our developers to register their 'plugins' as 'extensions'. It is not actually related to whether an extension is distributed as just a .rb file, or a .rbz or a .zip. Its just some calls they have to make in their code. Point is, don't be alarmed by the Extensions menu, its just a name change πŸ˜„ Old .rb files will still shot up in that menu, even though they used to show up in the Plugins menu.
                                It is very hit-or-miss as to which ooold .rb plugins can be copied over and still work. That is why you really really have to install them via the Extension Warehouse, the SketchUcation plugin store, or smustard, just so you make sure you are getting the most recent version. Then if you still have some .rb extensions that you can't live without, just copy them into your plugins folder like you used to. Just do it sin small batches. If one doesn't work, it might pop up a loading error. then you'll know which one failed, and you won't be able to carry that one forward. In that case, all you can do is track down the author and try to get an update, or try a different plugin with same functionality.
                                @david_h said:
                                And do i need to re-download and re-install my renderers? Podium, twilight, thea. .. etc etc etc? Thanks for the help
                                These are are ones that you will most definitely have to re-download their newest version, that is specifically compatible with SU 2015. Most extensions that have their own installers do things to your system that simply copying their plugin files from one version of SU to the next is bound to fail. So yeah, a good rule of thumb is that if it has its own installer, it definitely cannot simply be copied.
                                Hope that helps!
                                • david_hD Offline
                                  david_h
                                  Hey Chris! thanks for the reply. I feel like a newbie today. Cuz. .I kinda am.
                                  I am resigned to just reload everything. I'll muddle thru somehow. πŸ˜„
                                  https://www.youtube.com/watch?v=2O8gTIr4lys
                                  So .. .Chris. . .they treatin' ya okay over there in the land of Sketchup? You likin' that new gig?
                                  • quimQ Offline
                                    quim
                                    "Ons Gaan Nou Braai" an old South African Expression for we going to have a party (BBQ).
                                    Eish dis x64 is moving. loving it.
                                    WEBSITE http://www.q-prodesigns.co.za
                                      D
                                      Think of it as a good opportunity to do some housekeeping. Don't install those old plugins you never used anyway.
                                      • david_hD Offline
                                        david_h
                                        That is true. I am doing a lot of housekeeping on plugins. I think I was up to 24,764. I only use about 12.
                                          There you go! That's one or two plugins you won't need to download. πŸ˜„
                                          • david_hD Offline
                                            david_h
                                            Still having a bit of an issue getting Thea and Podium to show up. But I'm working on it.
                                            EDIT Well,. .. just got Thea. . .now onto podium
                                            • 15
                                            • 16
                                            • 6 / 16
