    Plugin that lists all your plugins?
    9 Posts 5 Posters 593 Views 5 Watching
    • KrisidiousK
      Krisidious
      Plugin that lists all your plugins? preferably a text file?
      By: Kristoff Rand
      • P
        Pherim
        I believe the plugins and extensions managers included in the Sketchucation Plugin Store Tools list all plugins and Extensions, not just those installed with it.
        • KrisidiousK
          Krisidious
          It does... But, not a text list that can be used in comparison to another. The bundles system seemed to miss quite a few, perhaps those that it did not have access to to reinstall.
          By: Kristoff Rand
          • P
            Pherim
            If you have your old version still installed, you could open it together with the new one and compare the plugins in the managers, maybe that helps.
            • BoxB
              You could use the Sets function.
              Create a set including everything and export it.
              The .set file can be changed to .txt
                You could use Q-Dir to compare the Plugins folders. Show the plugins folder for one version in one pane and the other plugin in another pane and look at them side by side.
                • KrisidiousK
                  Krisidious
                  Close... only puts a space between each plugin. runs them horizontal instead of vertical. quite the mess to look at.
                  I think this might be the closest thing.
                  I was wanting to use WinMerge to check the two files. I guess I'll have to trust my old eyes.
                  By: Kristoff Rand
                    Indeed the SketchUcation 'Plugins Manager' makes a list of all plugins 'by their folder'.
                    To get a sorted 'text' list of ALL installed plugins [even any 'disabled' ones] use this snippet in the Ruby Console [copy+paste+<enter>] [note that these have no 'file-type' suffixes, like '.rb'].
                    puts;puts SCF_Dialog.getMyPlugins.split("|").sort.join("\n")
                    To get plugins listed in different ways substitute ' getMyPlugins' with one of these...
                    getMyCloudPlugins == just those installed in your sketchUcloud folder - if you have one.
                    getMyDisabled == just those that are Disabled [.rb! etc]
                    getMyEnabled == just those that are Enabled [NO .rb! etc]
                    getMyExtensions == just those plugins files which can/do create Extensions
                    getMyHelpers == just those plugins which are 'helpers', probably needed by some other plugins, like 'offset.rb'...
                    getMyUninstalled == just those plugins which have been 'uninstalled' [.rbx etc]
                    There are two other slightly different methods thus:
                    This:
                    puts;puts SCF_Dialog.getMyPluginsFolders.join("\n") == all available plugins folders
                    And this method, which gives a complex list of plugins reported by folder.
                    puts;puts SCF_Dialog.getMyPluginsByFolder.split("||").join("\n\nFOLDER= ").split("|").join("\n") == The listing is in the format: the name of your Computer, the FOLDER= 'Plugins' with the folder's Ruby file contents sorted below - including any disabled ones - and then potentially FOLDER= 'sketchUcloud', 'Custom1' etc...
                    The SketchUcation PluginStore dialog's 'Bundle' system filters the lists to include just those which came from SketchUcation - so if you have say a Smustard.com plugin installed, although the Managers will list it, unfortunately it does not make it into your lists in 'My Downloads', 'My Installs'. or the related 'Bundle'...
                    • KrisidiousK
                      Krisidious
                      Boooom... You rock Tig.
                      By: Kristoff Rand
