    Plugin that lists all your plugins?
    9 Posts 5 Posters 428 Views 5 Watching
    • KrisidiousK Offline
      Krisidious
      Plugin that lists all your plugins? preferably a text file?
      By: Kristoff Rand
        Pherim
        I believe the plugins and extensions managers included in the Sketchucation Plugin Store Tools list all plugins and Extensions, not just those installed with it.
          Krisidious
          It does... But, not a text list that can be used in comparison to another. The bundles system seemed to miss quite a few, perhaps those that it did not have access to to reinstall.
          By: Kristoff Rand
            Pherim
            If you have your old version still installed, you could open it together with the new one and compare the plugins in the managers, maybe that helps.
            • BoxB Offline
              You could use the Sets function.
              Create a set including everything and export it.
              The .set file can be changed to .txt
                You could use Q-Dir to compare the Plugins folders. Show the plugins folder for one version in one pane and the other plugin in another pane and look at them side by side.
                  Krisidious
                  Close... only puts a space between each plugin. runs them horizontal instead of vertical. quite the mess to look at.
                  I think this might be the closest thing.
                  I was wanting to use WinMerge to check the two files. I guess I'll have to trust my old eyes.
                  By: Kristoff Rand
                  • TIGT Online
                    Indeed the SketchUcation 'Plugins Manager' makes a list of all plugins 'by their folder'.
                    To get a sorted 'text' list of ALL installed plugins [even any 'disabled' ones] use this snippet in the Ruby Console [copy+paste+<enter>] [note that these have no 'file-type' suffixes, like '.rb'].
                    puts;puts SCF_Dialog.getMyPlugins.split("|").sort.join("\n")
                    To get plugins listed in different ways substitute ' getMyPlugins' with one of these...
                    getMyCloudPlugins == just those installed in your sketchUcloud folder - if you have one.
                    getMyDisabled == just those that are Disabled [.rb! etc]
                    getMyEnabled == just those that are Enabled [NO .rb! etc]
                    getMyExtensions == just those plugins files which can/do create Extensions
                    getMyHelpers == just those plugins which are 'helpers', probably needed by some other plugins, like 'offset.rb'...
                    getMyUninstalled == just those plugins which have been 'uninstalled' [.rbx etc]
                    There are two other slightly different methods thus:
                    This:
                    puts;puts SCF_Dialog.getMyPluginsFolders.join("\n") == all available plugins folders
                    And this method, which gives a complex list of plugins reported by folder.
                    puts;puts SCF_Dialog.getMyPluginsByFolder.split("||").join("\n\nFOLDER= ").split("|").join("\n") == The listing is in the format: the name of your Computer, the FOLDER= 'Plugins' with the folder's Ruby file contents sorted below - including any disabled ones - and then potentially FOLDER= 'sketchUcloud', 'Custom1' etc...
                    The SketchUcation PluginStore dialog's 'Bundle' system filters the lists to include just those which came from SketchUcation - so if you have say a Smustard.com plugin installed, although the Managers will list it, unfortunately it does not make it into your lists in 'My Downloads', 'My Installs'. or the related 'Bundle'...
                      Krisidious
                      Boooom... You rock Tig.
                      By: Kristoff Rand
