    [Plugin] ExtrudelineTool Update
    72 Posts 28 Posters 84.8k Views 28 Watching
      Ah. I completely missed that plugin.
        bandararith
        how can i use this plug in??? i got the file extrudelinetool.rb, but i dont know where to pun it??? copy it to google sketchup file in drive(c:) or something. i so poor for this, please leave me the answer!!!
          Hi bandararith,
          Simply copy the file here:
          C:\Program Files\Google\Google SketchUp 8\Plugins
          • utilerU Offline
            utiler
            Hi Didier, love this plug-in!
            Just wondering if it's worth an option to hide geometry on curves and also an option o make a group or component?
            Cheers, A
            Just Curious...
            • designerbursaD Offline
              designerbursa
              arc problems 😞
                monmonred
                a sketchup 2014 update for this pleeeeease! πŸ˜„ thanks in advance!
                +Greatness may be measured on how much we have lost for the betterment of mankind+
                  As I have said in some other threads for to Didier's 'packed' plugins...
                  Edit the plugin's .rb file using Notepad.
                  At the end of the code it says:
                  .unpack("m")**.to_s**
                  change the end part to read
                  .unpack("m")**[0]**
                  Save and restart SketchUp...
                  It should now work fine in any SketchUp version.
                    Didier has agreed that I might update some of his Plugins in the PluginStore.
                    Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=extrudelinetool-Modified-TIG This is v2014/2015 compatible.
                      Pherim
                      Sketchup 2015 64bit sometimes freezes when I use this.
                        Ruby Console errors ?
                        It IS an old script - there are now better solutions.
                        I updated it for Didier, only for completeness... πŸ˜•
                          @pherim said:
                          No, it just doesn't react any more. This seems to happen particularly if the start point is set not on the selected line, but also sometimes if it is.
                          Can you recommend an alternative?
                          My Extrusion toolset http://sketchucation.com/pluginstore?pln=ExtrudeTools
                            Pherim
                              Pherim
                              Great, thanks! I already had that installed but I must admit I have never really taken a closer look at it, although your plugins are always top notch.
                              • josephkim626J Offline
                                josephkim626
                                Just to note,
                                This extension no longer generates face in 2017 version.
                                I suppose it is just not being updated.
                                  This a previously reported issue.
                                  It is being updated for v2017 compatibility... just that I haven't finished it yet !
                                  The way v2017 handles references and IDs changed and broke some of the EEby tools...
                                  I have most of them fixed - just tweaking the last few...
                                  There is actually a separate thread discussing this too...
                                    josephkim626
                                    Ah, sorry. I wasn't aware that there is another thread.
                                    Thanks for all the work TIG!
                                      lapx
                                      Thanks Tig! I am having same issue with extruding a line to face also.
                                      • boofredlayB Offline
                                        boofredlay
                                        TIG, any chance you can put this on the front burner? This is one tool I use(d) very frequently and I am missing it.
                                        Thanks.
                                          97% updated...
                                          I have to earn a crust too...
                                            Extrude line(s) is maybe the more useful tool in case of headache's situation!
                                            And of course with the new Quads world of SUbD ! πŸ€“
                                            (works yet fine in 2015, 2016! πŸ˜‰
                                            • 4 / 4
