    Three lines instead of one
    4 Posts 3 Posters 271 Views 3 Watching
      suSteve
      On the attached image I get 3 lines created at the top of the opening instead of 1. Even when I play around with it I still get 3. Why would that be?
      thank you
        kaas
        @susteve said:
        On the attached image I get 3 lines created at the top of the opening instead of 1. Why would that be?
        I guess some hidden lines are breaking your new line. Try <view> --> <hidden geometry>
          Also you might have edges/faces on an OFF layer that are also in the same context.
          NEVER put raw edges/faces onto a layer other than Layer0.
          Always have Layer0 as your active-layer.
          Layers do NOT separate geometry: layers merely control visibility.
          Having some edges on layers that are unseen, but which are still interacting is a recipe for impending madness 😲
          To separate things use groups of components to contain your geometry, and then assign layers to those groups or component-instances, switching a layer OFF then hides that group. πŸ€“
            suSteve
            thank you for the help
