    1.5k Posts 471 Posters 3.4m Views 470 Watching
      littleche
      oundCorner cannot do anything for this model, because it is triangulated.
      The method is to use Subdivision, which you may possibly try with Artisan by Whaat.
      thank you fredo for your help .
      I thought this work is Possible whit your plugin .
      I hope this Reliability Be included in future versions. πŸ˜›
        goblinteasemaid
        very nice tool, works on SU6
        doesnt do groups so you need to group edit or explode
        and you only get one chance for offset input. Get it wrong and you must revert to sharp edge start - obvious really, no big deal
        think of the time spent doing it manually YUK
        thanx mille foix
        Goblint
          goblinteasemaid
          F6 one thing I forgot to mention, I have an annoying issue with the drop down window in Round corners, its squashed up.
          window problem
            marcostakahasi
            i'm trying to install. where's the archive?
              It's very clearly spelled out in the first post on the first page of this thread.
              Don't forget to read and follow the rest of the directions.
              • fredo6F Offline
                Installation of my Plugins is now done via the SCF Plugin Store.
                • fredo6F Offline
                  You must have a screen with high resolution, analog to Retina screens on Mac.
                  Nothing to do, because this dΓ©pends on Sketchup and these problem of high rΓ©solutions screen are not fixed yet.
                  Possibly you can select the option "Retina screen" in the Default parameters of LibFredo6, but the correction is not guaranteed (see this thread).
                    gruzdev_f
                    Install all the instructions.
                    but what is it?
                      If you read the tool's installation guidance it explains that, as with most of Fredo's tools, it need a set of helper files installed too - 'LibFredo6'
                      You can get that from the PluginStore...
                      http://sketchucation.com/pluginstore?pln=LibFredo6
                      Install it, then restart SketchUp to ensure everything gets reintegrated...
                        gruzdev_f
                        As you can see in the screenshot, LibFredo6 installed but sketchup not see him.
                        LibFredo6 folder is where it is necessary
                          Sorry, I now see the problem.
                          You have a 'Cyrillic name'.
                          In v2014 FILE can return incorrectly if there are no ASCII characters in the Plugins folder's path, at least without further 'trapping' of errors.
                          I though Fredo has addressed the issue recently, when he updated his Lib and all of his tools.
                          Have you installed the very latest versions of all of Fredo's tools AND Lib from the PluginStore... ?
                          If so... if you make a Windows User account with an ASCII name [like "Fedos" ?] does it work ?
                            SketchMax
                            Hello Sketchupers!
                            First post here for me ever, I'm currently working as a 3d-modeler for a company in Sweden and I've been on it for soon 2Β½ months.
                            With that said I've tried to learn everything by myself now for 2Β½ months, so I'm still quite new to sketchup.
                            But I finally have come to some struggle and i tried to look around for solutions, but unsuccessful unfortunately.
                            My problem is that I got a dome-shaped object which is not entirely domy(Jokes aside) and I need the sloped side to the top to be more round without having to raise the top a few MM just to round the top of that(which also does not change the fact it won't look right).
                            I'll insert a picture for better understanding my situation(I hope).
                            http://i.imgur.com/kqcLh2j.png
                            The reason I post here is because I'm not to familiar with forums and such,
                            and for that I use your "Round Corners" ALOT! Kudos to that plugin.
                            I'm also sorry if I posted in the wrong forum.
                            I hope I didn't make this to complicated for you guys to understand and I thank you in advance.
                            //Max
                              snapster42
                              Roundcorner is a very useful plugin. But I am having some trouble using it for my purpose. I am trying to create a model for 3D printing, and one of the design requirements is that sharp edges should be avoided. Another requirement, however, is that the object must be a "water-tight" solid in the end, and I am having trouble satisfying that with roundcorner. For example, if I try to round the corners on something like this:
                              The plugin appears to work, but when I group it, it doesn't become a solid. I use the "solid inspector" plugin to see what's wrong, and it shows me this:
                              When I zoom in to this, I can't see any problem:
                              Has anyone encountered this type of problem, and found a solution?
                              • cottyC Offline
                                cotty
                                RoundCorner sometimes creates additional faces, in your case there is an internal face created and after you deleted this face, the object will get solid.
                                my SketchUp gallery
                                • fredo6F Offline
                                  That's probably the explanation. A face is created between the big and the small cube.
                                  Actually, RoundCorner does not create the face, it is rather Sketchup that does it automatically (i.e. find_face).
                                  • F Offline
                                    filonik
                                    Π― Π½ΠΈΠΊΠ°ΠΊ Π½Π΅ ΠΌΠΎΠ³Ρƒ Π½Π°ΠΉΡ‚ΠΈ Π³Π΄Π΅ ΡΠΊΠ°Ρ‡Π°Ρ‚ΡŒ сам ΠΏΠ»Π°Π³ΠΈΠ½.
                                    НС Π²ΠΈΠΆΡƒ слова БКАЧАВЬ.
                                    • pbacotP Offline
                                      @sketchmax said:
                                      Hello Sketchupers!
                                      //Max
                                      Welcome Max! You should try starting a new thread under "SketchUp Pro and Make Discussions". Looks like a possible solution would involve creating a better profile for the dome and remaking it, using FollowMe with a circlular path.
                                        snapster42
                                        cool, thanks for the tip. I'm fairly new to sketchup; any advice on how I delete this internal face? Do I have to hide some visible faces and then delete the internal one or something?
                                        • cottyC Offline
                                          cotty
                                          ΠŸΠΎΡΠΌΠΎΡ‚Ρ€ΠΈΡ‚Π΅ Π² ΠΏΠ΅Ρ€Π²ΠΎΠΌ постС.
                                          (You should try to use english here in the forum.)
                                          my SketchUp gallery
                                          • BoxB Offline
                                            Тми мСня
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 73
                                            • 74
                                            • 61 / 74
