    Obligatory Hoverbike
    83 Posts 16 Posters 15.0k Views 16 Watching
    • Bryan KB Offline
      πŸ˜† I meant the tail. You'll see. I have a far better idea and now I know how to achieve it. πŸ‘
      But thanks for compliments!
      • hellnbakH Offline
        hellnbak
        Been following this, progressing very nicely. Are you going to add some sort of windscreen at some point?
        • Bryan KB Offline
          Yes. Still fine tuning the body.
          This is more like what I had in mi.nd for the tail. Not perfect, but a lot, lot closer
          • Bryan KB Offline
            Minor updates and some finer detailing.
            • Bryan KB Offline
              Handlebar update. Almost done with them.
              • Bryan KB Offline
                Update.
                  It might look better if you used the aircraft instrument layout, you could use various picture downloads for those. If it is going to fly it will need a few more of those instruments.
                  • olisheaO Offline
                    olishea
                    Good idea Mike.
                    Some more inspiration, albeit a few years behind your jet/thrust based design.....but something which should be available to BUY in less than 5 years.
                    I thought it may be a gimmick at first...but it highlights the inherent danger behind helicopter flight. You can't easily just jump out with a parachute in case of complete failure. With this new hoverbike, any engine issues and you'll have two parachutes to bring you back to land.
                    oli
                    • Bryan KB Offline
                      Mike, there will be a full HUD in the windscreen/fairing. The instruments cluster you see now are mostly to give a semi-retro look and act as back up in case of HUD failure. However, the most basic instruments you need to fly are altimeter, air speed, compass, and fuel. The rest are engine temp and oil pressure and rpm. The last 2 are not needed on this bike.
                      Olishea, those are anti gravity pods. This is strictly a sci-fi design. πŸ˜‰
                      All that aside, thanks for the suggestions! πŸ‘
                      • Bryan KB Offline
                        Oh, and an artificial horizon. (almost forgot) πŸ˜„
                        • Bryan KB Offline
                          Sorry for the delayed update. Have some personal crisis I'm dealing with. Nothing medical, thank god.
                          Handlebars completed. There might be a minor tweak later, but this is pretty much it.
                          • Bryan KB Offline
                            Minor tweaks and rider is back for scale. All that's left is the front cowling.
                              On the home straight now mate, nice progression and a cool 'bike'.
                              • Bryan KB Offline
                                Thanks Mike. Just need to finish the cowling and I also want to redo the landing pads.
                                • Bryan KB Offline
                                  Landing pads reworked.
                                    liam887
                                    Nice work, the landing pads look a bit fragile, I would beef them up a little bit and maybe offset them at an angle so the struts don't point straight down (like attached).
                                    VISIT MY ONLINE GALLERY
                                    • Bryan KB Offline
                                      Thanks liam and thanks for the suggestion, but that's kind of overkill for a bike. πŸ˜‰ Think "kickstand."
                                      Originally I didn't even want landing pads. The bottom edges of the pods were to be rubber and act as the landing pads. I tried it as a suggestion and then just kept them as a "placeholder." I'm still thinking of getting rid of them entirely and going back to a variation of my original idea.
                                      However, since I'm not real happy with them, they will be last. I'm still working on the fairing/cowling. By working I mean visualizing.
                                      In my designs, I'm trying to move away from the "brutalist" and heavily mechanical/military look. http://en.wikipedia.org/wiki/Brutalist_architecture
                                      While I admire and appreciate the style, I really love sleek and flowing with a hint of mechanical, but I'm not that good with SketchUp yet to realize it. (see my previous posts of the colony ship and space naval cruiser)
                                        liam887
                                        Oh sorry I did not mean make them thick as in my example I merely meant make the offset to the centre of gravity to the bike so it is more stable. So rather than point exactly down they face forward maybe 30-40 degrees and slightly out to the side. If you land while you have nay forward momentum (as in if your not landing exactly 90 degrees) then it might just fall over. You could get over this by having wheels rather than pads. Does that make sense?
                                        • Bryan KB Offline
                                          Oh. Ah! Yes, that does makes sense. Funny you should also mention wheels... πŸ˜„
                                          Thanks for the follow up explanation. πŸ‘ A whole better design just flashed though my head.
                                          Thank you very much.
                                          • Bryan KB Offline
                                            Yep. Need to tweak the fairing a little bit.
                                            • 3 / 5
