    Login
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    21 Posts 7 Posters 11.0k Views 7 Watching
      Gábor
      @juju: I've checked the "remember me" function and it is working for me. Are you sure your browser is not set to erase cookies when you close it?
      @highlander: If you try to reply to a post when you're not logged in then you're re-directed to the login page. About the not logged in status: Did you check the "Remember me" checkbox? Are you sure that your browser is not set to erase cookies on closing it?
      • jujuJ Offline
        juju
        Hi Gabor, it does not happen all the time, only from time to time. If my browser was set to delete cookies at the end of browsing sessions I would have problems with other message boards / forums, not so?
        • H Offline
          highlander
          yes did check the 'remember me' box.
          Yes because other forums or login does 'remember me'.
          Sander Hoogland
          SketchUp 2018 pro - Vray
          Beeld3d
          • andybotA Offline
            andybot
            speaking of logins - would there be any way to make the store and the forum use the same cookies? If I go from forum to the store, it asks for my login, even though I'm already logged with the same user and pass in the forum. May be a technical reason why this has to be, but this thread made me think of it again.
            • BoxB Offline
              Did you just kick us all out, I had to login for the first time in ages just now.
                Gábor
                @andybot: The sketchUcation site uses 2 engines: PhpBB for the forums and Joomla for all the other content including the shop. These two systems are using their own session and authentication system what are bridged together so you have to register only at one system and you have to log in only to one of the systems and then you're logged in to both.
                For performance reasons the session timeout (the time while the system keeps you logged in after your last activity) is set to 60 minutes. If in any of the systems the inactivity exceeds that time, that system will log you out. That is what is happening when after a long-term activity in the forums you go to the shop and you find yourself logged out. So it is the nature of this kind of bridged system we have. There might be a way to let one system know about the activity in the other but that requires a deeper intervention in the authentication systems. Maybe one day with the next version of the site we will make it.
                @highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
                • andybotA Offline
                  andybot
                  thanks for the explanation Gábor. I assumed it was a technical reason, and had been meaning to ask.
                    Gábor
                    @highlander, @juju: I think the "Remember me" problem is fixed. At least I can not reproduce it again. If it occurs again, please let me know.
                    • jujuJ Offline
                      juju
                      @gábor said:
                      @andybot:****@highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
                      I have a bookmark to the URL: sketchucation.com
                      Thanks for looking into this, I will let you know if the problem occurs again.
                      • H Offline
                        highlander
                        @gábor:
                        👍 👍 👍 fixed
                        Sander Hoogland
                        Beeld3d
                        • jujuJ Offline
                          juju
                          yep, well it happened again this morning, had to login manually, didn't use the machine over the weekend...
                          • jujuJ Offline
                            juju
                            second visit today, didn't have to login either time.
                              Gábor
                              Thank you for the information. Did you log in from other machines during the weekend?
                              • PixeroP Offline
                                Pixero
                                I did also have to log in again every time today on both PC and iPhone.
                                • jujuJ Offline
                                  juju
                                  no I did not
                                    Gábor
                                    I'm trying to find out the cause but I have to admit that I'm not sure about the cause. Now I re-ordered the "remember me" module in Joomla to be the first to load. Please erase all your browser cookies, re log in with the remember me feature set and share with me if it helped or not.
