    Login
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    21 Posts 7 Posters 11.6k Views 7 Watching
    • BoxB
      Did you just kick us all out, I had to login for the first time in ages just now.
      • G
        Gábor
        @andybot: The sketchUcation site uses 2 engines: PhpBB for the forums and Joomla for all the other content including the shop. These two systems are using their own session and authentication system what are bridged together so you have to register only at one system and you have to log in only to one of the systems and then you're logged in to both.
        For performance reasons the session timeout (the time while the system keeps you logged in after your last activity) is set to 60 minutes. If in any of the systems the inactivity exceeds that time, that system will log you out. That is what is happening when after a long-term activity in the forums you go to the shop and you find yourself logged out. So it is the nature of this kind of bridged system we have. There might be a way to let one system know about the activity in the other but that requires a deeper intervention in the authentication systems. Maybe one day with the next version of the site we will make it.
        @highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
        • andybotA
          andybot
          thanks for the explanation Gábor. I assumed it was a technical reason, and had been meaning to ask.
          • G
            Gábor
            @highlander, @juju: I think the "Remember me" problem is fixed. At least I can not reproduce it again. If it occurs again, please let me know.
            • jujuJ
              juju
              @gábor said:
              @andybot:****@highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
              I have a bookmark to the URL: sketchucation.com
              Thanks for looking into this, I will let you know if the problem occurs again.
              • H
                highlander
                @gábor:
                👍 👍 👍 fixed
                Sander Hoogland
                SketchUp 2018 pro - Vray
                Beeld3d
                • jujuJ
                  juju
                  yep, well it happened again this morning, had to login manually, didn't use the machine over the weekend...
                  • jujuJ
                    juju
                    second visit today, didn't have to login either time.
                    • G
                      Gábor
                      Thank you for the information. Did you log in from other machines during the weekend?
                      • PixeroP
                        Pixero
                        I did also have to log in again every time today on both PC and iPhone.
                        • jujuJ
                          juju
                          no I did not
                          • G
                            Gábor
                            I'm trying to find out the cause but I have to admit that I'm not sure about the cause. Now I re-ordered the "remember me" module in Joomla to be the first to load. Please erase all your browser cookies, re log in with the remember me feature set and share with me if it helped or not.
