    Login
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    21 Posts 7 Posters 10.4k Views 7 Watching
    • H Offline
      highlander
      hello
      login does not work??
      this is what I do:
      1 forum top right, login.
      2 get a pop-up screen. Login (username and password) and checkbox for each visit checked.
      3 then nothing still have login on the top right instead of username.
      I'm using firefox.
      Can some one tell me what I should do.
      Sander
      Sander Hoogland
      SketchUp 2018 pro - Vray
      Beeld3d
      • Rich O BrienR Online
        How did you post here if you were not logged in?
        • jujuJ Offline
          juju
          h4xz0r
          on a more serious note:
          I too have issues where the forum forgets (ie. opposite of remember me) my login, all other boards / forum work normal, just here on Sketchucation I have to login fresh (with remember me) from time to time. It's very definately not a setting on my machine as I've experienced it on various machines, both Mac and PC.
            Gábor
            @juju: We will investigate and fix it if necessary.
            • H Offline
              highlander
              @rich
              When I press reply (or new subject). I get redirected to a another login screen (not the pop-up login) there I can login and is working. But here's the thing, when I check automaticly each visit and come back later that day, there the same problem I'm not logged in.
              Sander Hoogland
              Beeld3d
                Gábor
                @juju: I've checked the "remember me" function and it is working for me. Are you sure your browser is not set to erase cookies when you close it?
                @highlander: If you try to reply to a post when you're not logged in then you're re-directed to the login page. About the not logged in status: Did you check the "Remember me" checkbox? Are you sure that your browser is not set to erase cookies on closing it?
                • jujuJ Offline
                  juju
                  Hi Gabor, it does not happen all the time, only from time to time. If my browser was set to delete cookies at the end of browsing sessions I would have problems with other message boards / forums, not so?
                  • H Offline
                    highlander
                    yes did check the 'remember me' box.
                    Yes because other forums or login does 'remember me'.
                    Sander Hoogland
                    Beeld3d
                    • andybotA Offline
                      andybot
                      speaking of logins - would there be any way to make the store and the forum use the same cookies? If I go from forum to the store, it asks for my login, even though I'm already logged with the same user and pass in the forum. May be a technical reason why this has to be, but this thread made me think of it again.
                      • BoxB Offline
                        Did you just kick us all out, I had to login for the first time in ages just now.
                          Gábor
                          @andybot: The sketchUcation site uses 2 engines: PhpBB for the forums and Joomla for all the other content including the shop. These two systems are using their own session and authentication system what are bridged together so you have to register only at one system and you have to log in only to one of the systems and then you're logged in to both.
                          For performance reasons the session timeout (the time while the system keeps you logged in after your last activity) is set to 60 minutes. If in any of the systems the inactivity exceeds that time, that system will log you out. That is what is happening when after a long-term activity in the forums you go to the shop and you find yourself logged out. So it is the nature of this kind of bridged system we have. There might be a way to let one system know about the activity in the other but that requires a deeper intervention in the authentication systems. Maybe one day with the next version of the site we will make it.
                          @highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
                          • andybotA Offline
                            andybot
                            thanks for the explanation Gábor. I assumed it was a technical reason, and had been meaning to ask.
                              Gábor
                              @highlander, @juju: I think the "Remember me" problem is fixed. At least I can not reproduce it again. If it occurs again, please let me know.
                              • jujuJ Offline
                                juju
                                @gábor said:
                                @andybot:****@highlander, @juju: I could reproduce the phenomena with the forum part now. So if I use a direct link to the forums sometimes it won't remember me. Never happened if first I went to the main sketchucation site. Am I right that it is only happening with direct link to the forums? If yes, I'll try to fix it.
                                I have a bookmark to the URL: sketchucation.com
                                Thanks for looking into this, I will let you know if the problem occurs again.
                                • H Offline
                                  highlander
                                  @gábor:
                                  👍 👍 👍 fixed
                                  Sander Hoogland
                                  Beeld3d
                                  • jujuJ Offline
                                    juju
                                    yep, well it happened again this morning, had to login manually, didn't use the machine over the weekend...
                                    • jujuJ Offline
                                      juju
                                      second visit today, didn't have to login either time.
                                        Gábor
                                        Thank you for the information. Did you log in from other machines during the weekend?
                                        • PixeroP Offline
                                          Pixero
                                          I did also have to log in again every time today on both PC and iPhone.
                                          • jujuJ Offline
                                            juju
                                            no I did not
