    Problems with my Moon Buggy
    43 Posts 11 Posters 3.1k Views 11 Watching
    • hellnbakH Offline
      hellnbak
      Only 557KB.
      Well, at least it was an interesting modeling challenge and I did learn a lot, so it wasn't a total waste (just seems that way ๐Ÿ˜† )
      • BoxB Offline
        Beautiful modeling, but for the sake of the rest of the model you should look at a texture. That way you get to do the whole thing and can even put the real mesh wheel on it when completely finished.
        Here is a 3 second one done with just the su fence texture. With a bit of work you could have a beautiful texture created with your model that would work perfectly and you would still know you could create the mesh yourself as you have already done it.
        You could even use Ghost Comp by fredo to drop the real ones in when needed.
        http://sketchucation.com/forums/viewtopic.php?p=180536#p180536
        • hellnbakH Offline
          hellnbak
          Thanks for the suggestions Box.
          Ghost Comp does sound promising, but at this point I think I will just chalk it up to experience. Too many other great things out there just waiting in line to be modeled.
          Maybe I'll give it a go later.
          • KrisidiousK Offline
            Krisidious
            fantastic... I was going to ask what would happen if you just went with half tire pure geometry as a comp and then multiplied. But looks like you've got it. there's nothing like modeling the real detail for realism. Can't wait to see more.
            By: Kristoff Rand
            • hellnbakH Offline
              hellnbak
              Couldn't get to sleep so thought I would take another stab at this. Took pbacot's suggestion and reduced the number of sides (four didn't look right so I went with six) and opened up the weave a bit to reduce the number of components. Here's the result of my insomnia
              It's closer now to the real wheel (might have to tighten up the weave a bit)
              But as you can see the numbers have dropped significantly, and the model is pretty easy to work with now.
              Just might proceed with this thing.
              • cottyC Offline
                cotty
                ๐Ÿ‘
                my SketchUp gallery
                  Just to compare why modifier stacks work better than components.....
                  To reach the final form a very simple piece of geometry is needed. Around 48 vertices....
                  By adding an array, then a curve you get the tyre profile. Another array and curve gives you the form that only needs mirroring....
                  I know the final shape is not correct but it illustrates why modifier stacks are so powerful. You can edit and tweak until your heart is content.
                  Here you can see it is 268k faces. And the viewport is as snappy as if there was only 1 vert.
                  Might be worth taking up Blender to make such detailed models. You are punishing SU with your modeling practices.
                    Krisidious
                    I'd wait and stick with sketchup... something will come along.
                    By: Kristoff Rand
                    • hellnbakH Offline
                      hellnbak
                      Rich, twenty years ago I might have taken your advice. But until I perfect my time machine there's just no way I am ever going to attempt to learn another program. Haven't even figured out this one yet, but I usually manage to get the job done, at least to my satisfaction. Sort of.
                      Sadly, I know my limitations, and trying to reach beyond them would only frustrate me even more.
                      I appreciate the advice tho, I really do.
                        This isn't about SU not being able to do it.
                        It's more about educating a user that SU isn't a Swiss Army knife.
                        Certain modelling practices require different tools.
                        If I was to tackle this in SU I'd be using transparent textures to lower memory usage and scene management.
                        • BoxB Offline
                          Ok, but would be a shame if you don't eventually tackle it with your incredible attention to detail.
                          • hellnbakH Offline
                            hellnbak
                            C'mon Rich, of course SU is a Swiss Army knife. The tricky part is figuring out how to use all the blades and tools ๐Ÿ˜‰
                            Still messing around with the wheel. Gotta tighten up the mesh yet
                              I think it's the fact you use SketchUp as your presentation tool and the added level of detail in projects that cause your bottlenecks.
                              It's not fault of SU or you but more a junction where you change trains.
                              It can do what you ask but at a price.
                              • hellnbakH Offline
                                hellnbak
                                Ah, but then there's the sense of accomplishment when I do finally manage to figure something out. Of course two weeks later I can't remember how I did it, but whaddaya gonna do?
                                  One thing is guaranteed. Your end result is gonna be stunning.
                                  • BoxB Offline
                                    Sometimes Rich, using the right tool for the job doesn't produce the desired result.
                                    Creating art isn't about doing things the easy way it's about self expression.
                                    Hellnbak's models aren't something mechanically produced, they are highly detailed artworks much like the pencil sketches people do that look like photos. You could suggest they just use a camera. Getting the realism he does using sketchup it what makes them particularly outstanding and inspirational to other modellers.
                                    • andybotA Offline
                                      andybot
                                      keep on rockin' that moon buggy hellnbak! Like Box says, your modeling is inspirational. ๐Ÿ˜„
                                        @box
                                        Absolutely.
                                        • hellnbakH Offline
                                          hellnbak
                                          Really appreciate all the kind words.
                                          Wow, I do art?? ๐Ÿ˜ฎ
                                          • pbacotP Offline
                                            Yep. Amazing!
                                            • 1 / 3
