    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      Tinanne,
      You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
      Can you check
      • tinanneT Offline
        tinanne
        I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
        Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
        Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
        Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
        Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
        defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
        • fredo6F Offline
          At least you seem to have no problem with my scripts.
          Try to remove the su_grid plugin which seems faulty
          • tinanneT Offline
            tinanne
            A ha! Finally! No more errors. Thank you!
            • fredo6F Offline
              Well. Glad you fix it
                teulerguimaraes
                I use SU2014. Install automatic from SketchupUcation plugin. Help please.
                http://i59.tinypic.com/2z74y02.jpg
                • E Offline
                  eozel
                  It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
                  I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
                  • fredo6F Offline
                    Might be related to the username if it includes non-ascii characters.
                    This is a known problem with SU, which I hope will be fixed.
                    • E Offline
                      eozel
                      It is probably bucause of username, my pc's username has a character "รถ". When i try this plugin on the other pc of mine, it worrked which doesnt contains no asci character. It is difficult change ๐Ÿ˜„ username directory name.
                      Thanks.
                      • fredo6F Offline
                        @eozel,
                        Thanks for the feedback.
                        2 questions:
                        1. Are you able to run LibFredo6 alone. I mean does it load normally and do you see the menu Windows > LibFredo6 Settings
                        2. Which of my plugins do you use.
                        If it is RoundCorner or Curviloft, and keeping your username, could you try to substitute the following files instead
                        Fredo6_!LibFredo6.rbFredo6_Curviloft.rbFredo6_RoundCorner.rb
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v6.2a - 12 Oct 14
                          LibFredo6 6.2a is a release mainly for EdgeInspector 1.2.
                          It also fixes the issue of installation on SU14 when the username includes non-ascii characters
                          See main post of this thread for Download of LibFredo6.
                          • E Offline
                            eozel
                            Hi, i installed libfredo 6.2a on my pc which inclued as a username "รถ" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
                            • fredo6F Offline
                              @eozel,
                              I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
                              I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
                              If so, then I will republish for the other plugins.
                                Ben Ritter
                                The download link does not work for me for either one of the plugins.
                                • fredo6F Offline
                                  Which download link? I only publish via the SCF PLugin Store.
                                    Ben Ritter
                                    OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
                                    Thanks again for sharing.
                                    • E Offline
                                      eozel
                                      As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
                                      Thanks four your supports.
                                      • fredo6F Offline
                                        Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
                                        At least this shows that LibFredo6 is correctly installed
                                        Maybe a snapshot of your Plugin directory would also help.
                                        • E Offline
                                          eozel
                                          I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
                                          thanks.
                                            I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
                                            Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 108
                                            • 109
                                            • 42 / 109
