    [Plugin] s4u_toComponents
    89 Posts 26 Posters 107.0k Views 26 Watching
    • hdpvH Offline
      hdpv
      You try delete old version in folder plugin sketchup
      Suforyou
      http://www.sketchupforyou.com
      • pep75P Offline
        pep75
        YES it Works! Now I've the 'Immense' toolbar! πŸ˜‰ Thanks again!!!!
          Finaly you make it free / Donate ?
          Use it here in this little thing πŸ˜‰
          • hdpvH Offline
            hdpv
            It's free for super tester Pillou! πŸ˜„
            Suforyou
              Magic of the auto similarity no uniform! πŸ˜„
              http://s6.postimg.org/ujv4ivopd/simili1.jpg
              • hdpvH Offline
                hdpv
                Additional,It work correct for all sublevel of Component,keep hierarchy.
                Suforyou
                  Very cool! β˜€
                  And when you have triangular face use
                  Quadrilateralizater by TIG
                  http://s6.postimg.org/u9wukide9/quads.jpg
                  PS For the inverse
                  by Renderiza Face Split triangulate all faces! β˜€
                  • hdpvH Offline
                    hdpv
                    Good combination! πŸ˜„
                    Suforyou
                      Made with Extrude Tools by TIG
                      Weld Curves : Recurve by Digssey
                      Selection Toys by Thomthom
                      Make 2 Arcs Circles + 1 profile
                      (option Quadrilaters)
                      Trick is Select only Soft Edges then Kill them
                      • DareDevilD Offline
                        DareDevil
                        I just tried Faces to Components with SU pro's dynamic components and it works 😍
                        Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
                        The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
                          boilingsnow
                          Great plugin!
                          thank you.
                          • hdpvH Offline
                            hdpv
                            @boilingsnow said:
                            Great plugin!
                            thank you.
                            Hope you like new feature too!
                            Suforyou
                              gfgfgfgfgf10
                              hi dear
                              15 dollars !!!
                              what do you think about us ???
                              do you think we are rockefeller in new york city !!!
                              πŸ˜’ πŸ˜’ πŸ˜’
                              • hdpvH Offline
                                hdpv
                                if you can't ,you use this free plugin
                                http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
                                it's like my plugin. πŸ˜‰
                                Suforyou
                                  laudhi
                                  @gfgfgfgfgf10 said:
                                  hi dear
                                  15 dollars !!!
                                  πŸ˜’ πŸ˜’ πŸ˜’
                                  you do not have to be rockefeller to buy this plugin... 😎
                                  better spend $ 15 rather than i have to make this plugin... πŸ˜‰
                                  • Y Offline
                                    yohdubato
                                    Hello,
                                    A member of thea render's forum told me to post my work to explain how great is your plugin !!! πŸ˜„
                                    I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
                                    it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, eiffel with su4u.jpgyour plug is still a must πŸ˜„
                                    πŸ‘ πŸ‘ πŸ‘
                                    • hdpvH Offline
                                      hdpv
                                      Yohdubato! nice model! πŸ˜„
                                      You can reset scale component by 2 plugins
                                      s4u_Scaletool ,free
                                      http://sketchucation.com/pluginstore?pln=s4u_scaletool
                                      or
                                      s4u Transformer,20$ (selectable origin components)
                                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
                                      Cheers!
                                      Suforyou
                                      • Y Offline
                                        yohdubato
                                        thanks for your links ; those plugins are great too!!!
                                        i will try them πŸ˜„
                                        πŸ‘ ++
                                          cruelcomedy
                                          I want this plugin, how do I get the full version and how do I pay for this?
                                          http://www.richarddoble.com/
                                          • hdpvH Offline
                                            hdpv
                                            Hi Cruelcomedy!
                                            Price: 15$
                                            Send to my paypal (suforyou.vn@gmail.com) for get it.
                                            Suforyou
                                            • 3 / 5
