    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 97.7k Views 32 Watching
      After months of development, with our focus now on v3, we are happy to get this last release of the v2 series out.
      2.6.1 is an incremental update with lots of changes.
      These are the main changes...
      • The Uninstaller highlights duplicate Plugin files in the lists if you have multiple Plugins folders and have some duplicated RBs [even if one is disabled] in 'pink'. You can then Uninstall the one you don't want and the setup is tidied...
      • The Plugins Manager and Extensions Manager dialogs are now interlinked [for >=v2013]. So if you have a disabled Extension its loader Plugin is shown 'grayed' in the Plugins list - to show that although it is loading the Plugin is not actually doing anything. AND if you have disabled a Plugin its previously activated Extension is shown 'grayed' in the Extensions list - to warn it will not be loaded after a restart, since the Plgin won't load and set it up.
        If both Manager dialogs are open the one changes dynamically to match the others status.
      • The MySetUp Updater tools now automatically work out where to put each updated RBZ's contents in a multi-Plugins folder setup [e.g. Default-Plugins, Cloud and Dropbox].
      • The Cloud button always installs into the user's sketchUcloud/plugins folder.
      • If a user is NOT a 'cloud' participant they do not see the submenu, 'cloud' button etc...
      • You only get a choice of destination if one exists AND you are doing an 'AutoInstall' using the red-button [but Cloud folder is NOT offered?].
      • The SketchUcation submenu RBZ/ZIP Installer works like the red-button.
      • The Bundle installer also offers you destination choices where possible...
      • The RBZ's download and installation of its contents is appreciably faster with >=v2014...
      • The SCFapi bugs are pretty much ironed out and there are options to switch it off if a user still has difficulties - say on a file-walled corporate network...
      • The SCFapi has some addition author tools available.
      • OxerO Offline
        Oxer
        Hi Rich,
        How I obtain a count in SketchUcation Cloud?
          Hi Oscar,
          The Cloud aspect is in beta.
          It works it is just that we are working on a separate project for the last few months.
          We haven't really finalised how we intend to roll-out the cloud system as yet. But those testing it do love it!
          That doesn't help you though?
          We'll have a chat in the morning about it and see what we can do.
          • OxerO Offline
            Oxer
            Thanks for the info Rich!!
            Waiting this new feature with anxiety 🎉 😄
            • JClementsJ Offline
              JClements
              I am curious as to how the UPDATE feature works.
              1- Does it ping the user's PC to see what they have installed?
              or
              2- Build a data base on a SketchUcation server for each user based upon what they have downloaded via SketchUcation?
              At any rate, it seems to work seamlessly. My thanks to the SketchUcation team for its foresight in developing the Tools Plugin.
                GĂĄbor
                Version 2.6.1 gets the list of downloaded plugins from the server. So the "downloads" TAB shows what is stored in the downloads log of the server about the user's downloads. Then this list is filtered and only those plugins of this list is shown in the "Installs" list what are really installed on the actual hardware at the moment. This filtering is done by using the names of the .rb files on the local machine.
                • Bob JamesB Offline
                  Bob James
                  What about those in "Additional Folders" in Dropbox?
                    It should include those ?
                    Doesn't it ?
                    • erkanE Offline
                      erkan
                      I'm having issues with AutoInstall in Sketchucation Plugin as I'm receiving the below error, although I have the Admin rights in my computer it's managed inside the Enterprise framework. So I've combined my Security settings (not sure what Special Permissions mean) with that error message and would appreciate if anybody can offer some directions to test for. OS is Windows 7 Enterprise Edition sketchucation_plugin.JPG
                        @Erkan
                        What version of SketchUp ?
                        By default in v20.. the folders in the User's AppData tree should already have FULL permission ?
                        Can you Auto-Install an RBZ using Preferences > Extensions > Install button ?
                        Can you Auto-Install an RBZ using the SketchUcation toolset's submenu 'Archive Installer' ?
                        Is this message just with the PluginStore dialog within SketchUp ?
                        Does your Windows User name include any unusual characters - like accents or Cyrillic ?
                        I can't make out the name in the top of the dialog - it looks to have something between the two parts of the User-Name ?
                        Can you copy/paste this text into the Ruby Console, + <enter> and post the result...
                        Sketchup.find_support_file "Plugins"
                        Can you also try this...
                        File.exist?(Sketchup.find_support_file "Plugins")
                        Does it return true or false ?
                        If it's false that's the problem...
                        Try version SketchUp v2014, or change your Windows User name to an ASCII one...
                        Pre-v2014 accented/cyrillic/etc User names can cause installation issues as the Plugins folder can't be found by Ruby, or PCs...
                        • erkanE Offline
                          erkan
                          Hi TIG, thanks for yuor help, please find my answers to your questions.
                          2014
                          Yes
                          No, I get the same error, also when I go to the website http://sketchucation.com/plugin/123-plugin clicking Download link won't conclude, the browser keep on "Waiting for plugin.sketchucation.com" I'm feeling stuck in 2014, good thing that I haven't removed SU 8 and performing some operations over there.
                          Yes
                          No
                          There's a dot after the name, Name.Surname@domain.com This cannot be edited as it's a part of the corporate IT environment.
                          Result C:/Users/Name.Surname/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                          true
                          What do you think?
                            I've asked GĂĄbor to look into this too...
                            Have you got SketchUp / sketchUcation.com allowed in your Firewall settings ?
                            Have you definitely set the User's Plugins folder Properties > Security > Edit permission to FULL, for each of those listed and applied/OK ?
                            Have the permissions trickled down to all subfolders and files within that Plugins folder ?
                            If you open the SketchUcation tools Plugins Manager can you see the contents of the User's Plugins folder ?
                            Can you change them [e.g. disable one] ?
                            If you exit SketchUp and try again have those changes been kept ?
                            Can you send be by PM a screen shot showing all of your files/subfolders within Plugins 😕
                            • erkanE Offline
                              erkan
                              Firewall is managed centrally by IT I'll ask this; any specific port should be asking?
                              As you can see in my previous screenshot I have the Full access already, I can't change as it's managed by IT. I will definitely ask for a fresh update on that from IT.
                              N/A
                              Yes
                              Nope
                              N/A
                              Coming right up in your PM inbox
                                It looks like one of your IT guys "is protecting you from yourself".
                                You need FULL read/write/modify permissions to your User's Plugins folder, AND these must also apply to the folder's contents.
                                I suspect that there is some subtle limiter set up by them [perhaps under 'Advanced' ?] which you might not appreciate viewing the Properties > Security listings ?
                                Perhaps it could also be Firewall related ?
                                You'll need to have some meaningful discussions with your IT guys...
                                Good luck.
                                PS: Can you also set up [or get IT to set up] your SketchUp.exe to always run as administrator - under Properties > Compatibility - this might help too...
                                  Jim
                                  How are you determining if a folder has "FULL Read/Write security permissions?"
                                  • erkanE Offline
                                    erkan
                                    Right click on the folder Plugins, then properties as shown in the above screenshot.
                                    • erkanE Offline
                                      erkan
                                      Good luck.
                                      Thanks TIG I'm waiting for them to try out some options to test.
                                      I was able to set it up, didn't help much so far.
                                        leminilab
                                        The plug-in doesn't seem detect my Sketchup Make 2015. Is it normal (not implemented yet) or is there something I must do to fix this?
                                        Oh, and before I forget: the bundle option is a hit! Thanks a lot for that! 👍
                                        • "Live every day as if it were your last and then some day you'll be right."
                                        • "ThomThom rules!!!"
                                        • KrisidiousK Offline
                                          Krisidious
                                          it's ready and should be the first plugin you install. you are installing it from the downloaded file in 2015 correct?
                                          By: Kristoff Rand
                                            leminilab
                                            Yes. Downloaded here http://sketchucation.com/resources/plugin-store-download and installed from Window/Preferences/Extensions menu.
                                            But Make 2015 doesn't show in the Bundle tab:
                                            • 1 / 7
