    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 144.1k Views 39 Watching
    • cottyC
      cotty
      Is it possible to get the result in the back (one step) if you place the drill shape at a border?
      my SketchUp gallery
      • fredo6F
        [attachment=0:6kxwbix7]<!-- ia0 -->drill_border.jpg<!-- ia0 -->[/attachment:6kxwbix7]
        Just make the rectangle a little bit higher. With exact dimensions, VisuHole has difficulty because it does know the original border faces stay.
        • Y
          yiannis76
          I can not use this plugin.Whetever i try to do i get the attached error
          VisuHole error
          • cottyC
            cotty
            Is it possible to snap the stencil shape (drill thru) to guide points, guide lines? Or to use the normal inference system for positioning the hole?
            my SketchUp gallery
              You can yet with this little trick and if your face volume is Parallel to one axe! ๐Ÿ’ญ
              Draw your guides lines crossing anywhere you want
              Then call the Stencil and Press one of the the Keyboard Arrow (so x, y, z axis)
              The snap will be fine on the crossing guides lines! ๐Ÿ˜‰
              Curiously don't work with a Guide Point on the surface but Yes if the Guide Point is on the empty space! ๐Ÿ˜ฎ
              So put the Guide Point on Guideline(s) who will be itself on the surface volume! ๐Ÿ˜„
              Edit : seems you cant draw your stencil on any position on the space of one Guide Line!
              So no need to press the Arrows'keys! ๐Ÿ˜„
              But not on their intersection! Even Drawn a Point Guide at the intersection first! ๐Ÿ˜ฎ
              All must be on the surface of the volume! ๐Ÿค“
              Guide line(s) + Point Guide
              • O
                optimaforever
                WWWWWWWonderful script indeed! ๐Ÿ˜„
                • N
                  numerobis
                  ๐Ÿ˜
                  Fantastic plugin! (as usual ๐Ÿ˜‰ ) Thank you very much! ๐Ÿ‘
                    We have yet the rotation ๐Ÿ‘
                    but...
                    ... does this is possible ? ๐Ÿ˜„
                    Will be very smart! ๐Ÿ˜„
                    And a Gizmo with separated scale X, Y, Z super smart! โ˜€
                    • W
                      Whaat
                      Congrats Fredo! Another great release! I am looking forward to playing with this one... ๐Ÿ‘
                      • ElibjrE
                        Elibjr
                        Fredo this looks amazing! I can 't wait to play with this one!
                        • fredo6F
                          NEW RELEASE: VisuHole v1.1a - 19 Oct 14
                          VisuHole 1.1a is required for the support of usernames with non-ascii characters in Sketchup 2014
                          See main post of this thread for Download of VisuHole.
                          • MALAISEM
                            MALAISE
                            Once more time, awsome tools. ๐Ÿ˜„ MALAISE
                            La Connaissance n'a de valeur que partagรฉe
                              reboot05
                              This is an awesome plug-in, thank you! I have one question, if for example I punch a hole in a component it seems to make that component unique and doesnt make that change to what were instances of the original component. It cant see to find if there was an option to make the change to all instances of the component. Other "typical" changes on components are working properly. Am I doing something wrong? Or have some preference set wrong?
                              Thanks again!!
                              • fredo6F
                                Thanks again!!
                                You have the choice
                                1. If you are outside the component, only the component selected is affected (and thus is made unique)
                                2. if you are inside the component, then all instances will be affected.
                                  skogen75
                                  Just found this...awesome indeed. Any tips on how to position the drill on guide points or lines? The stencil seems to disappear when I hover over a guide cross or guideline that intersects a face. I would love to know how to accurately place the drill. Very cool. I'm using SU15.
                                  • P
                                    Pants
                                    +1.
                                    I think this is what <pilou ยป Sat Sep 27, 2014 10:55 am> was describing (along with a workaround?) and if so, I don't get his results, or just don't understand exactly what he was suggesting to do the workaround.
                                    I can NOT get it to punch through any semblance of guidelines, pencil-lines, etc. The stencil disappears as soon as it infers an intersection point - though yes, arrow-keys seem to bring it back as per previous post, but...still...there's no punching going on. Yes, I can punch to my heart's content if I just "get random" with it, but I'm trying to hit precise measurements, not do an art piece where measurements don't matter.
                                    Fantastic capabilities, but for me...entirely hamstrung by this flaw. Help!
                                    Downloaded today with Sketchucation plugin store - Downloads: 3037 [ Version Updated: 2014/10/19 ]
                                    • fredo6F
                                      Thanks for signaling.
                                      I normally fixed this ennoying problem in version 1.2a, now available on the PluginStore
                                      • fredo6F
                                        NEW RELEASE: VisuHole v1.2a - 04 Feb 15
                                        VisuHole 1.2a fixes a major bug preventing to drill when the cursor is positioned on a Guide line, Guide point or Edge over the target face.
                                          Super! Works very fine on Guides Line, Guides points! โ˜€
                                          No news for a Gizmo size just before drawing the Stencil ? ๐Ÿ˜„
                                          But something is always wrong on the edge sides! ๐Ÿ˜ฎ
                                          Works on the edges as soon as there is a little angle! ๐Ÿ˜‰
                                          But when pararall not! ๐Ÿ˜ฎ
                                          visuhole_hum01.skp
                                          • fredo6F
                                            @pilou
                                            The problem for border edges is different. It deals with the fact that the stencil is usually partially outside of the shape. VisuHole only accepts to drill if the pivot point is inside the shape.
                                            No I need to fix that as well.
                                            PS: for the Gizmo, it is on my list. VisuHole is actually not a finished plugin, but I don't know when I will resume work on it.
                                            • 2 / 6
