    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 141.7k Views 39 Watching
    • F
      function
      mega
      • F
        feixia1127
        Yup a new cool one!
        • OxerO
          Oxer
          Incredible plugin!! 👍
          I have done the Spanish Translation but there are some strings missing in the language file:
          • Current Stencil
          • Next Stencil in History
          • Previous Stencil in History
          • Pick a Stencil Shape in the Model
          Spanish Language File
          • fredo6F
            Oxer,
            Thanks a lot. Actually, part of the strings are in LibFredo6.
            • OxerO
              Oxer
              I know it, I have uploaded the new Spanish Language for LibFredo6 v6.1a but these are missing strings to translate in VisuHole:
              • "Current Stencil"
              • "Next Stencil in History"
              • "Previous Stencil in History"
              • "Pick a Stencil Shape in the Model"
              • "PICK A STENCIL SHAPE"
              • "Pick a Stencil Shape - Click / Release to pick or Click / Drag / Release to pick and orientate - Ctrl down to Force faces - Esc to cancel"
              • fredo6F
                Oxer,
                There seems to be a small problem, maybe for because of the '/'.
                Still I was able to translate these strings to French. So I need to clarify.
                Fred
                • OxerO
                  Oxer
                  Thanks for the reply!
                    AcesHigh
                    Awesome, I will try as soon as I can.
                    Quick question before downloading it: saw the first minutes of the tutorial video... when moving the stencil shape over the surface you want to apply the stencil, it seems the stencil is "grabbed" by it´s middle.
                    Is it possible however to for example, move a stencil by it´s corner, and then position it precisely somewhere?
                      Yes of course! ☀
                      When you select a new stencil you choose its own origin and even its orientation! 😉
                      And when you draw it on the volume again position and orientation (on the volume) are possible! 🤓
                      A must indeed! 😎
                      • cottyC
                        cotty
                        Is it possible to get the result in the back (one step) if you place the drill shape at a border?
                        my SketchUp gallery
                        • fredo6F
                          [attachment=0:6kxwbix7]<!-- ia0 -->drill_border.jpg<!-- ia0 -->[/attachment:6kxwbix7]
                          Just make the rectangle a little bit higher. With exact dimensions, VisuHole has difficulty because it does know the original border faces stay.
                          • Y
                            yiannis76
                            I can not use this plugin.Whetever i try to do i get the attached error
                            VisuHole error
                            • cottyC
                              cotty
                              Is it possible to snap the stencil shape (drill thru) to guide points, guide lines? Or to use the normal inference system for positioning the hole?
                              my SketchUp gallery
                                You can yet with this little trick and if your face volume is Parallel to one axe! 💭
                                Draw your guides lines crossing anywhere you want
                                Then call the Stencil and Press one of the the Keyboard Arrow (so x, y, z axis)
                                The snap will be fine on the crossing guides lines! 😉
                                Curiously don't work with a Guide Point on the surface but Yes if the Guide Point is on the empty space! 😮
                                So put the Guide Point on Guideline(s) who will be itself on the surface volume! 😄
                                Edit : seems you cant draw your stencil on any position on the space of one Guide Line!
                                So no need to press the Arrows'keys! 😄
                                But not on their intersection! Even Drawn a Point Guide at the intersection first! 😮
                                All must be on the surface of the volume! 🤓
                                Guide line(s) + Point Guide
                                • O
                                  optimaforever
                                  WWWWWWWonderful script indeed! 😄
                                  • N
                                    numerobis
                                    Fantastic plugin! (as usual 😉 ) Thank you very much! 👍
                                      We have yet the rotation 👍
                                      but...
                                      ... does this is possible ? 😄
                                      Will be very smart! 😄
                                      And a Gizmo with separated scale X, Y, Z super smart! ☀
                                      • W
                                        Whaat
                                        Congrats Fredo! Another great release! I am looking forward to playing with this one... 👍
                                        • ElibjrE
                                          Elibjr
                                          Fredo this looks amazing! I can 't wait to play with this one!
                                          • fredo6F
                                            NEW RELEASE: VisuHole v1.1a - 19 Oct 14
                                            VisuHole 1.1a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                            See main post of this thread for Download of VisuHole.
                                            • 1 / 6
