    [REQ] Symmetry tool
    13 Posts 5 Posters 882 Views 5 Watching
    • PixeroP Offline
      Pixero
      I would like to have something like the symmetry modifier in 3dsmax in SU.
      It creates a plane which you can rotate for example 45 degrees to create a angled mirror of a object which is cut at the intersection.
      Great for creating things like corner cabinets or corner windows.
      See this page for some info: http://knowledge.autodesk.com/support/3ds-max/getting-started/caas/CloudHelp/cloudhelp/2015/ENU/3DSMax-Tutorial/files/GUID-42DD88AC-4988-4CBB-A3FE-6298B1ECC9B3-htm.html
        Mirror by 3 Points by Tig don't makes that ?
        And if you use before Slice2 by Surfoyou what do you want more? πŸ˜„
        (for have a vertical cut "straight" the trick is use the "View Top" Parallel camera)
        Or even before the new VisuHole by Fredo6 who is also a very good solid slicer! πŸ˜‰
        • PixeroP Offline
          Pixero
          I use mirror by TIG regularily. Havent tried the other script.
          I was thinking of a auto cut along mirror axis function included for better workflow.
            Cut an object is two seconds ! Call the Mirror and apply is 3 seconds! All is 5 seconds!
            That avoid some headache to the ruby developper! πŸ˜„
              I can see adding a final rotational option (graphically on screen) would be a cool addition to the Mirror tool
              • PixeroP Offline
                Pixero
                Yes, and the Max modifier does it in a way so that you can change things afterwards but I guess that would be asking too much? Would it be doable with section cuts per object?
                • BoxB Offline
                  It would certainly be interesting if you could select a plane and have whatever geometry you draw appear reversed on the other side.
                  It can make such a difference sometimes seeing the symmetry as you design.
                    It would be an interesting thing indeed. Of course it can already be done with the use of components.
                    • BoxB Offline
                      Yes but I like the idea of doodling symmetrically and see what you get, rather than making flipped components to start with. Plus if everything was mirrored while tool is active. Raw geometry/components/arrays etc etc
                        Minor inconvenience. πŸ˜„
                        • BoxB Offline
                          Yes yes Dave I know I know, I often have models made of multiple flipped and twisted components. All I'm saying is it would be handy to be able to drop a plane into a complex model and know that whatever you drew on one side would appear on the other.
                          People want plugins to wipe their bums for them, can't I too?
                            I know. And you should have that plugin. πŸ˜„
                            Actually I think it would be cool, too.
                            • PixeroP Offline
                              Pixero
                              ...and having such a plugin could easily turn any linear object to a angled one.
                              Imagine doing a detailed window with all the frames and then, voila, it's a corner window. 😎
