    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 631.4k Views 155 Watching
    • fredo6F Offline
      I suggest you have a look at the documentation for the selection and the VCB (Measurement box) usage.
      There are options to select individual faces, surfaces, all-connected faces and faces with the same material.
      For the selection: click/release on the selected faces and click again on the last face selected without leaving it. You should be in dragging mode.
      For the offset, it does not matter which move you have done. Type the value, press Enter and JPP will set the offset as typed.
        BorgMan
        Sorry Fredo, I'm trying as hard as you say, but it just won't work. Furthermore, I don't know how long I'm supposed to long-click as the help box says, but that's not working for me either, as does click-release and, as mentioned, the VCB's stubborn inability to listen to which values I enter. It only looks at how far I pulled out the shape and then ignores any entered values when I press Enter. I reinstalled the old JPP toolset and that one works just as you said, without so much of a hickup 😞
        On the other hand, it might have something to do with my install. Check this out: whenever I try to make a regular arc [1] and let it tangent [2], it breaks up my arch into its loose edges [3]. Ofcourse, this sucks, because a Follow Me command will result in the shape that I let it follow to be broken up as well, which would result in a lot of repair work and I don't want that, ofcourse.. But when don't let it tangent, the resulting line stays uninterupted, except at places where it crosses another line (duh) [4]. Sooo... Anyone else who had this here little problem?
        Select line tool...
        Let it tangent...
        Loose edges? That's new?
        No tangent? No loose edges! Eh?
        More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
        You've gotta love Slivers.
          BorgMan
          By the by, I got this error when opening SketchUp. Does this help out?
          Sketchup error.txt
            That is most likely because you have not updated to SketchUp v2014M1 which fixes a known issue.
            In SketchUp v2014M0 PC if you launch SketchUp by opening a SKP that is on a drive other than the drive where SketchUp.exe is located then it messes the S: list.
            Thus the Ruby2 stuff never gets loaded and tools like the SCFapi that rely on some functions fail.
            You should find that starting SketchUp from the menu and then opening a SKP does NOT create this issue.
            There is a fix rb file that went into Tools and sorted the $: out, BUT simply installing SketchUp v2014M1 is advisable, as it also fixes a few other glitches under the hood.
              cosmorobus
              not selected polygons. What's the problem?
              I have
              Fredo6_JointPushPull - v3.2b - 17 Mar 14
              LibFredo6_v6.0b
              Sketchup 14.0.4900
              • I Offline
                interior_design
                It is really helpful in modeling which gives more precise and flexible design, indeed.
                Many thanks to the author: Fredo.
                  littleche
                  I have a problem with JointPushPull ...
                  As you can see in the picture ,I can not pull this face Properly.
                  The parts that I've marked with a green line ,JointPushPull is destroyed face .
                  What can I do to fix this problem? ❓
                  JP&P.skp
                    Well, to start with, you've got some reversed faces. Instead of fixing them, you've tried to mask them by making the front and back faces the same color. That's not the right way to take care of the problem. Correct the face orientation and try again.
                    Then try scaling up by maybe 100 to avoid smaller faces.
                    • BoxB Offline
                      Apart from the reversed faces that Dave has pointed out, you have a layer other than Layer0 as the active layer, always keep 0 active, keep all raw geometry on Layer0 and only place groups or components on other layers. Also your linework is bad. Your edges are rough and don't form clean curves.
                        Indeed! And as is typical of computer stuff, GIGO applies here.
                        • BoxB Offline
                          Just a couple of examples to show you what you need to fix.
                          This whole section is twisted
                          The red circle shows where the edge is kinked without any corresponding geometry.
                            littleche
                            "Dave R" & "Box" Thanks for your help ...
                            revers and oriant face does not affect the performance of jointP&P plugin.
                            Yes, I agree my linework is bad but in bad line plugin good working !
                            I have tried many different ways But according to the your advice I still was not able to reach my goal.Another way to tell if it is possible ...
                            Is not this a bug in the plugin?
                              It would be nice to blame the plugin because your bad line work is causing the problem, wouldn't it? 😒
                              • BoxB Offline
                                It's not a fault with the plugin, it is attempting to follow what you have drawn.
                                Get everything on the same layer and clean up your geometry and the plugin works.
                                I've no idea how you drew it in the first place but perhaps it would be easier to start again and get the geometry right rather than trying to repair it.
                                  littleche
                                  This problem was solved! Thank you for your help ... my worklin was very bad .I got to practice tips that you said and Finally I drew a good workline with tools on surface plugin and jointpull&push It's nice to end. 😍
                                  and Again, thanks ... 👍
                                  • BoxB Offline
                                    Well done.
                                    Learning to get your structure right in the first place is far better for you than getting a plugin to work.
                                    • fredo6F Offline
                                      NEW RELEASE: JointPush Pull Interactive v3.3a - 19 Oct 14
                                      JointPushPull Interactive 3.3a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                      See main post of this thread for Download of JointPushPull.
                                        mvsuriano
                                        Hello - I've been using the old version of JPP for some time - its awesome. Recently tried to install the newest version via SketchUcation tools in SU 2014.
                                        I see the toolbar, however, clicking on any button/tool in the JPP toolbar doesn't do anything, it just defaults to the tool I had selected prior.
                                        Any suggestions?
                                        Mike
                                        • cottyC Offline
                                          cotty
                                          Any suggestions?
                                          Mike
                                          Did you update LibFredo to version >=6.3? Are there error messages in the ruby console?
                                          my SketchUp gallery
                                          • fredo6F Offline
                                            @mvsuriano,
                                            Could you open the Ruby Console before clicking on the JPP icon, in case there are error messages displayed
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 30
                                            • 31
                                            • 17 / 31
