    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Jorgensen
      hi pilou
      it seems to make no difference if i select a density of 5 or 20, the polygons never get more than 10017.
      i'm properbly do something wrong, but i don't know what πŸ˜•
        Jorgensen
        My fault - i set density to high.
          amos_miers
          Has anyone experienced the generation of the items heavily in some portions and light in others, following hard diagonal lines dividing the place? I cannot seem to apply the script evenly in most of my spaces. I am using 2014.
            If they are visible : Cleanup by Thomthom : Merge Coplanar Faces
            If they are invible, Enable Hidden Geometry : Selection Toys by Thomthom
            Select Soft or Smooth Edges then kill them
            • hajkardiH Offline
              hajkardi
              I have problem on slope terrain with plugin. I try to change all parameters but no luck?! Some parts of terrain is cover properly, but some have lack of grass. I download last version of plugin 2.1.0 and I have Sketch 2013 pro.
              http://i.imgur.com/k02tm7X.jpg
                Ayomidotun
                Thanks Bro!
                  tak2hata
                  Hi,haikardi.
                  Sorry for my reply too late.
                  I guess the problem is "MaxNumber(/Face)".
                  Please set high value to "MaxNumber(/Face)".
                  "MaxNumber(/Face)" is limit for creating too much fur.
                  by TAK2HATA
                  • soloS Offline
                    I love this plugin, really helps me to distribute grass proxy's. I do have one request, sometimes even the lowest values are too much, I'd really like to distribute (make crowd) with .5, .2 values.
                    Oh!v a distribution brush would also be most welcome.
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      What do you mean by that?
                      Something like Components Spray?
                      • V Offline
                        Vincy_PC
                        how to install in skp 2014?
                          Read the first post of this thread.
                          • V Offline
                            Vincy_PC
                            how install in skp 2014
                            • BoxB Offline
                              [screenr:27dfvywo]o3nN[/screenr:27dfvywo]
                                jiminy-billy-bob
                                how play the video
                                • cottyC Offline
                                  cotty
                                  play good
                                  my SketchUp gallery
                                  • soloS Offline
                                    Please, I ask again if it would be possible to go lower than 0.1 in crowd place setting, I love this plugin but on a large terrain I seem to have no control as lowest setting is still too much.
                                    • F Offline
                                      feyade
                                      @lasrador said:
                                      This is just brilliant.. Don't know how i missed this for so long. Now that vray2.0 is proxy enables the possibilities are limitless.. Convert a grass component into a proxy on sk (Though 3dsmax allows the porxy to be simplified further), import it into the model and scatter the proxy. You have a feather weight model with the punch of a heavy weight! Awesome work tak2hata! 😍
                                      this was my first attempt at grass..
                                      http://i42.tinypic.com/ncdyf6.jpg
                                      hi,
                                      quick question how did u manage to achieve this render. can't figure how to setup my settings
                                      • H Offline
                                        hilalevi
                                        it doesnt work on sketchup 2014. what do i need to do to make it work?
                                          Yes. It does work on SketchUp 2014. The first thing you need to do to get help making it work is give specific and useful information. How did you install it? Which version? What are you expecting to see that you aren't seeing?
                                          • OsamaAlshamiO Offline
                                            OsamaAlshami
                                            Hi tak
                                            tanks for tool it's very useful.
                                            I translate it to ArabicLanguage. πŸ˜„
                                            only little problem with translation.
                                            "Main" & "Default"phrase not translated in (web dialog) ❓
                                            Arabic translate for (Make Fur).
                                            • 32
                                            • 33
                                            • 7 / 33
