    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 311.1k Views 89 Watching
    • mtripleM Offline
      mtriple
      thx TIG,
      i'm still learning (i'm noob), u guys helped me alot.
      i'm waiting ur cloth simulation xd.
      compospray workin 2014
        JamesCE
        It was a permissions error for me, but it is working now. I also didn't know much about using the ruby console. Thanks!
          JamesCE
          @tig said:
          Permissions to folders within the Programs Files tree is limited by default.
          As has been said before... you should never need to put ANYTHING into the Tools folder.
          The default 'User' Plugin folder for v2014 has suitable permissions...
          I am still at a loss as to see what is improved by this fiasco... πŸ˜’
          I assumed that the permissions were changed by the company I work for. I didn't realize it is like that by default. To fix it I actually downloaded the latest link and installed it the correct way. I didn't realize that mtriples other link was a bad fix, and I'm still confused to how dtarch got it to work..
          The reason I said that I fixed it by fixing the permissions issue is because I assumed it wasn't like that by default and assumed it could be just changed to get it to work for people that were having that same issue. I was trying to be helpful but it ended up being wrong and more confusing 😲 sorry
            paul.wacko
            I tried placing the files into Tools and Plugins without success
            However when I placed them in Tools and ShippedExtensions folders, where the tools folder is it fired up. But not in the plugins folder.
            Paul J
              keithswd
              Does anyone know how to get this plugin working on a Mac install of SU2014? I get this error after installation:
              Error: #<SyntaxError: /users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:511: Invalid break
              /users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:520: Invalid break>
              Error Loading File compoSprayToolbar.rb
              Error: #<NoMethodError: undefined method compSpray_env' for main:Object> /Users/keithpocock/Library/Application Support/SketchUp 2014/SketchUp/Plugins/compoSprayToolbar.rb:7:in <top (required)>'
              • OxerO Offline
                Oxer
                On Mac & SU2014 you have to place the compoSprayToolbar.rb file and ComproSpray folder is this path:
                /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools
                Go to Applications folder select SketchUp app and right click Show package content
                  keithswd
                  Thanks Oxer. I have just tried putting the file & folder as you suggest but still get the error. I have double checked that there is no longer a copy in either user Application Support../Sketchup subfolders, or in the system support folder, but up pops the error when I start up.
                  The error has changed to the updated path for the script, so maybe something else is wrong:
                  Error: #<SyntaxError: /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:511: Invalid break
                  /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:520: Invalid break>
                  Error: #<NoMethodError: undefined method compSpray_env' for main:Object> /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/compoSprayToolbar.rb:7:in <top (required)>'
                  • soloS Offline
                    So, any solution? I tried downloading it with the SCF plugin store but that did not work well, in fact it installs but nothing, no tool bar not in plugin menu, anyone?
                    • OxerO Offline
                      Oxer
                      KeithSWD and Solo, try with this version updated by MTriple, it works fine for me on Mac OS X & SU2014, remember the path on OS X:
                      CompoSpray
                        keithswd
                        Many thanks Oxer (and MTriple) this version is working for me too!
                        Glad to have this very useful tool back in operation.
                          ruriglen
                          The file MTriple uploaded to dropbox is offline, does anyone else has it, that kindly could uploaded again for sharing? Thanks!
                            penumbra
                            I give up on this plugin. Does not work on 2013 even the Mtriple fix. It won't accept a second point on the shapes (circle, square you name it). The developer has gone MIA...
                            • BoxB Offline
                              It does work on 2013 and 2014 with some tweaks.
                              Make sure you have the properties set to what you need and remember it needs a surface to spray on.
                              As for the developer being MIA, Didier has never said he supports this free plugin in perpetuity.
                              • chonC Offline
                                chon
                                Hello,
                                no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
                                Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
                                Any one to help me ?
                                Thanks a lot !! πŸ˜‰
                                • nghminh81N Offline
                                  nghminh81
                                  Thanks so much Oxer and MTriple. Your file works perfectly with my sketchup 2014!
                                  To anyone who using Windows and still can't install it: Please extract files(ComposprayToolbar.rb and 1 folder Compospray) to "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools".
                                  DON'T EXTRACT FILES TO "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
                                  AND IF THEY WERE THERE (Because you tried to install it) Just DELETE.
                                  • V Offline
                                    valerostudio
                                    Agreed. This works in 2014! Thanks!!!
                                    • faBcnF Offline
                                      faBcn
                                      Hi there,
                                      I do not see any window when clicking on Draw / Compo spray (SU 2013)...
                                      Any idea ?
                                      Thanx
                                      • faBcnF Offline
                                        faBcn
                                        How I manage to make it work on SU 2013, here in Spain (with bloody accents everywhere...)
                                        1- Copy/Paste CompoSpray folder + .rb in Plugins file as usual
                                        2- Remove all .lingvo but CompoSprayUS.lingvo
                                        and it works perfectly ! Nada mΓ‘s....
                                        • chonC Offline
                                          chon
                                          Not for me in France ! 😞
                                          Still not working with my config...
                                          • V Offline
                                            valerostudio
                                            Broken again in 2015!!!
                                            • 13
                                            • 14
                                            • 8 / 14
