    Urgent help!!!!! Pushpull Problem (SOLVED)
    8 Posts 6 Posters 922 Views 6 Watching
    • holmes1977H Offline
      holmes1977
      Hi Guys
      I have come across this problem in the past and solved it. But can't remember and cant find any solutions online. There are 2 problems which must be linked together.
      PROBLEM 1
      PROCESS
      1.) I draw a square (4 lines and a face)
      2.) Use the push/pull tool to form a cube
      RESULT
      The square (4 line and a face) moves in the direction I use the push/pull tool without forming a cube.So it acts like the move tool.
      PROBLEM 2
      PROCESS
      1.) Select the paint bucket tool
      RESULT
      Instead of the paint bucket tool appearing the select paint (eye dropper) appears.
      Exaggeration makes a dull story better.
      • KrisidiousK Offline
        Krisidious
        You're sure your mouse isn't having issues?
        By: Kristoff Rand
        • S ShepherdS Offline
          S Shepherd
          I think you may have a stuck alt key on your keyboard.
          Shep
            I would concur with Scott. Both of those behaviors are the things you would expect from those tools when the Alt key is held down.
              holmes1977
              Hi Team
              Like I said this has happened before.
              I re-installed nvidia drivers and the problem has solved itself. Like you guys, it felt like a stuck key problem. I do remember now that re-installing graphics driver fixed it last time. How that seems to effect certain tools in SU I have no idea.
              Thanks so much for your help
                Weird but I'm glad you figured it out.
                • panixiaP Offline
                  panixia
                  what a "doh" moment! ๐Ÿ˜ฎ never noticed the pushpull+alt quickly moves faces without extruding them.. this could be handy sometimes.. thank you! ๐Ÿ˜›
                  • ely862meE Offline
                    ely862me
                    Not for me ... ?!?
                    Elisei (sketchupper)
                    Come and See EliseiDesign
