    [Plugin] Trilateration (Update)
    24 Posts 14 Posters 33.5k Views 14 Watching
    • Didier BurD Offline
      Didier Bur
      Updated today with settings. See top.
      DB
        kwistenbiebel
        Looks nifty, but could someone explain for what purposes this is to be used?
        • BepB Offline
          Bep
          Hi Didier,
          You must be clairvoyant.
          You worked out this part of my sugestions exactly as I wished it to be.
          And that far better as I described it.
          I'v got the feeling we are insync on this.
          Thanks, and greetings,
          ๐Ÿ‘ ๐Ÿ‘
          Bep van Malde
          "History is written by the winners"
            Didier Bur
            All is in the name: trilateration and in the doc: "intended to draw triangles when 3 sides lengths are known".
            Useful to draw non-orthogonal room plans based on telemeter triangular measures, for instance, survey, amoung other apps.
            DB
              jstanton8869
              I've been using this plugin for several years and it's VERY useful. How can I install it on Sketchup 2014? If it doesn't work is there an alternative plugin that does trilateration which I use for survey data
              John
                Myrillan
                Please, really need an update for Sketchup 2014
                /Anna
                • sdmitchS Offline
                  sdmitch
                  I think it is the same problem as with most of Didier Bur's scrambled plugins. You need to edit the code at the end as described in this post.
                  404 Not Found
                  (sketchucation.com)
                  http://sdmitch.blogspot.com/
                    jstanton8869
                    404 Not Found
                    (sketchucation.com)
                    Excellent, Thank you so much - it worked perfectly for me.
                    • GMthompsonG Offline
                      GMthompson
                      This plugin has been a awesome tool for me in the past, I do architectural metals, canopies, awnings, tension structures and many other miscellaneous adventures,
                      Is there a compatibility issue with 2014 as i cannot seem to install this wonderful tool, no complaints she still works fine in 2013
                      [url][/url]
                      you can learn something everyday by paying attention
                        As with many of Didier Bur's very useful plugins, it probably needs updating. He seems to be very busy in other areas and hasn't updated them, though. There's a little editing that might possibly make it work in SU2014. I'll see if I can find the thread where it was mentioned although someone else may beat me to it.
                          Found it. Take a look at this post by TIG. I'll bet the same editing he recommends will fix the issue here, too. I haven't looked but that seems to be a common thing with Didier's plugins.
                          Or you could have just read the post above yours. ๐Ÿ˜’
                            GMthompson
                            Thanks Dave, me finding time to edit the source would be awesome, but i have 0 time on my hands and learning new things becomes a uncontrollable addiction for me......lol, it works still in 2013
                            This tool is a life saver if you use SU for field construction with compound overlapping scalene triangles, ๐Ÿ‘ this helps me bring together realistic overlapping geometry and its pretty easy to use
                            • BoxB Offline
                              It takes less time to edit the rb than it would have taken you to write that you don't have the time to do it.
                                Didier has agreed that I might update some of his Plugins in the PluginStore.
                                Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=trilateration It is now compatible with v2014/2015.
                                  rowseeoh
                                  Total noob here. The instructions in this zip file ARE EVERYTHING! thank you
                                  • O Offline
                                    obones
                                    Hello,
                                    This plugin seems amazing but I could not get it to work with Sketchup 2016.
                                    I mean, it installs properly, it shows up in the menu.
                                    I then started using, placed the first end, then the second and finally I entered the two values separated by a semicolon as requested in the status bar.
                                    I then pressed enter and nothing happens, the triangle does not draw. However, I can see that Sketchup is now using one CPU core fully.
                                    Is there something I should look at to make it work with Sketchup 2016?
                                      I just installed it in SU2016 and it worked for me. Are you sure you are following the prompts at the bottom of the screen?
                                      Click to open
                                      • O Offline
                                        obones
                                        Yes, I do, but debugging it, I found out what's wrong:
                                        Basically, I input values that would give a really thin triangle and so are "out of range" for the computation to work. It thus calls UI.messagebox to display an error message.
                                        However, on my system, this dialog box is showing behind the main Sketchup GUI, meaning I can't see it.
                                        The only way to bring it back on top is to Alt-Tab to other applications and back.
                                        • sallyS Offline
                                          sally
                                          Hello Didier, will you be updating this for SU 2020. I am lost without it!! Complement perdue!
                                          Merci beaucoup ๐Ÿ˜„
                                            @sally
                                            It isn't signed for newer SketchUp versions, but it should still work if you have your Extension Manager's > Extension Loading policy set to 'Unrestricted'...
                                            Install it and try using it with the Ruby Console open...
                                            If it works, fine - if it fails, then at least you'll see some error messages ??
                                            Many older plugins are no longer being supported, and so they aren't signed for newer SketchUp 'full-compatibility' - however, many of them will still work...
