    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 790.8k Views 175 Watching
    • OxerO Offline
      Oxer
      I have installed ExtrudeTools in SU 2013 & 2014 on Mac and the plugin works fine but there is a problem with spanish translation, all lingvo files are in UTF-8, I haven't modified them, the translation works ok in Menu, tooltips of the toolbar and Extrude Edges By Offset tool, the rest no.
      This is very strange, do other users with the same problem?
      Mac OSX 10.9.2, SU 2013 & SU 2014, no messages in Ruby Console.
        @Oxer do you have the very latest set ? v2.4.
        I had to do an update because some of the lingvo files were encoded incorrectly...
        If I understand you correctly...
        The translations works in Menus, Toolbars' tooltips and all text for the 'Extrude Edges By Offset' tool.
        But nowhere else in any of the other 'EEby' tools 😕
        To double-check I swapped all of my EN-US lingvo names for ES...
        I confirm that oddly the translations work as you set out.
        For some reason I can't see the dialogs etc in all but the Offets tool remain in English, although checking for the strings in the rb and lingvo files shows a proper match...
        BUT I HAVE NOW found the errors in the coding... 😕
        I'll issue an update to fix this asap... 😒
          http://sketchucation.com/pluginstore?pln=ExtrudeTools
          Here is an updated version in the PluginStore, v2.5.
          It fixes various longstanding, but previously unreported, glitches with some of the lingvo files...
          • OxerO Offline
            Oxer
            Thank you very much TIG!! 👍
            Now the translations work fine again.
              mishgan
              hi,
              how can i download this plugin??? i don't see the zip file...
              • massimoM Offline
                massimo Moderator
                  @mishgan said:
                  hi,
                  What Massimo said. Or you could download the RBZ file and install it automatically via Install Extension or, even better, install the Sketchucation Plugin Store and install it automatically that way.
                  • I Offline
                    iivvaann
                    Hello. I have an error reboot after installing Extrude Tools v2.5 .:
                    Error al cargar archivo C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb
                    Error: #<LocalJumpError: unexpected return>
                    C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb:33:in <module:ExtrudeTools>' C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb:23:in <top (required)>'
                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                    C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:68:in register_extension' C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:68:in module:ExtrudeTools'
                    C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:29:in `<top (required)>'
                      Your Windows user-name is Iván - with an accent !
                      Prior to v2014 user-names containing accented characters were well known to cause issues with Ruby scripts - e.g. when using 'File' methods [you still show v8 in your user-profile, but the reported error is in v2014].
                      This issue is improved in v2014... BUT such accents etc can still cause problems in FILE related code used by many scripts...
                      I'll try coming up with a fix and reissue this toolset shortly - look for a new version later today...
                      Let me know if it works...
                      However, having an accented user-name WILL still cause issues with SketchUp pre-v2014... AND in several other toolsets' code in even v2014 too.
                        Here's v2.6 http://sketchucation.com/pluginstore?pln=ExtrudeTools
                        It is re-coded in an attempt to allow users who have accents in their Windows user-name to still successfully load and use the toolset in v2014...
                        • I Offline
                          iivvaann
                          Woo uuu !!! Excellent, it worked instantly. Thank you very much TIG, my laptop is new and the seller put the accent on the user name. I was already forming to not have this plugin. Thank you very much for taking the time to help me. Thank you again. Greetings.
                            Glad to be of help... 😄
                            If you get similar issues with other scripts, then please let the author know.
                            This kind of report is rare, but there are possible workarounds - at least for v2014...
                              Pherim
                              Extrude Edges by Faces by Rails makes my SU2015 64bit always crash immediately after finishing - it works fine on the same model in SU2013. No error message, just crash and bug splat window the second I click yes or no to erasing the original curves.
                              All other tools work.
                              It's amazing though, how much faster this and many other operations are executed in the new 64bit version.
                                Looks like we ought to continue this issue in this 'Extrusion Tools' thread ?
                                I'll investigate...
                                PS: I see the issue too, trying to see its cause 😕
                                  Pherim
                                  Your recommendation in the other thread made me try out every tool in this set, and that's how I discovered this issue.
                                  Sorry for keeping you busy like this. 😉
                                    Here's v2.7, now in the PluginStore
                                    http://sketchucation.com/plugin/1103-extrudetools
                                    The update covers ExtrudeEdgesByRailsByFace - it has been adjusted to work properly in v2015, which unexpectedly showed a glitch when calling another tool from within its mouse-click method...
                                    As a 'side-effect' it also has some improved graphics, prompting etc...
                                      Pherim
                                      I confirm that it works now. Thanks!
                                      • H Offline
                                        Hecky001
                                        Hello there i am here to report a crash of my sketchup 8 pro when using Extrude Edges by Rails by Face
                                        it crashes only when the profile its segmented more than 12 times for example if a segment a circle 13 times it will crash the sketchup a bug splat but when i segment circles below 12 it does the job fine can someone please tell me whats going on
                                          Manijeh
                                          I have just installed this plugin through plugin store tool bar's autoinstall.
                                          I watched the video on youtube and followed step by step. but the tools didn't work for me.
                                          Is there any way there could be a more detailed video tutorial preferably with audio?
                                          Also am I missing something in the operations and or installation of this tool?
                                          Thanks for your response.
                                          Manijeh
                                            perper
                                            No toolbar
                                            Can anyone assist me?
                                            I have downloaded the TIG Extrude tools to SketchUp.
                                            Unfortunately I can not find the toolbar..
                                            Pls help
                                            Best regards
                                            Per
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
