    Nonsolid object becoming solid when exported to Cura
    17 Posts 4 Posters 10.5k Views 4 Watching
      Marcus is of course correct - unless you intend your model to be made out of pieces - make sure all geometry is linked into a single form.
      Any links will also need to follow the rule about 'partitions' where they abut the main geometry at their ends...
      A 'solid' can still have 'discrete parts', and that don't affect its 'solidity'; BUT depending on the material used some printers will charge extra for it effectively being several separate objects in one file...
        autumnalblues
        Thanks for all the tips, guys! πŸ˜„ Yes, I'll add some geometry connecting the free-floating eye and mouth. πŸ˜„
          d12dozr
          Great, and please post photos of the finished print and cookies once you make them! πŸŽ‰
          http://goo.gl/f7ooYh
            autumnalblues
            I most definitely will. πŸ˜„
              autumnalblues
              Here is the finished cookie cutter, guys. πŸ˜„ Can't wait to try this on fondant and make sugar cookies! πŸ˜„
              • cottyC Offline
                cotty
                Nice result!
                my SketchUp gallery
                  d12dozr
                  Looking good!
                    autumnalblues
                    Hello again, guys! πŸ˜„
                    I'm making an Anna cookie cutter this time around. πŸ˜„ For the life of me, I can't figure out what's wrong with the model. I still have a lot to learn on Sketchup, indeed. πŸ˜„ The neck becomes solid when I export it to Cura. 😞 Kindly check attached files.
                    Would anyone be able to point out what's wrong with the model?
                    Thank you. πŸ˜„
                    Anna This Is It Outline 2.skp
                      To check if any model is a solid you need select all of the relevant geometry and make it into Component [or Group].
                      Its "Entity Info" will not include the word 'Solid' in its header if it is not a solid.
                      Sadly it is not a solid.
                      It is racked with internal partition faces.
                      Use thomthom's Solid-Inspector to see the many issues.
                      My SolidSolver cannot fix it as the issues are two convoluted...
                      To fix it, edit it cut a section-plane looking down so you can see inside it.
                      Erase any internal facets and faceless edges [select+<del> key].
                      Remember that a solid object can only contain faces and edges, and every edge must have two faces - no fewer and no more !
                      Internal partition faces mean there will be edges with only one or more likely three or more faces.
                      There are some faceless edges, and you have a part meeting at a point - meaning that edge has four faces !
                      A little remodeling is needed 😞
                        autumnalblues
                        Thanks TIG. πŸ˜„ I really appreciate the help. πŸ˜„ I most definitely need to remodel Anna. πŸ˜„ Just a small favor: can you take a screenshot of the part that has four faces? πŸ˜„
                          See this...
                            autumnalblues
                            Fantastic! Thanks a lot, TIG. πŸ˜„
