    Really interested in GPU using VFSU
    renderpluginsextensions
    23 Posts 7 Posters 3.4k Views 7 Watching
    • srxS Offline
      srx
      @srx said:
      I use Thea4SU IR Presto AO CPU+GPU engine. 15-30 minutes per interior daylight picture of great quality in 3000 resolution (i7+GTX760). If you need even better, you also have IR Presto MC which is perfect, but 50-100% more time.
      Some of them 50% of the original size...Of course, my goal was not to make art out of rendering, but to make fast variations of the design. For that purpose it was enough.
      www.saurus.rs
        cuttingedge
        Those are decent renders Srx. I am vray for SU renderer but would be willing to shift (say to Thea) if that's what will satisfy my requirements in quality and much needed speed.
        To make myself clearer , I attached here a sample of what we normally do. at 3000 resolution. This takes 3 to 4 hours. I wonder if by some good hardware, I could make it say, 10 minutes...
        My boss would even want an instant 3 seconds full high res. What kind of machine could deliver this?
        Image originally rendered at 3000
        • soloS Offline
          Can you share that or another model so we can test using Thea?
          I will second the praise for Thea's speed using the Presto engine, however as mentioned above it will depend on the setup, what I see above in your meeting room render I will be comfortable to believe Thea could knock that out in minutes.
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            Yes Presto is fast!
            But on Vray it shouldn't take 3-4h on decent hardware, you may have unoptimized settings.
            Sharing the file is a good idea.
            • V Offline
              valerostudio
              I would never wait 3-4 hours for any render. If you have multiple workstations, try setting up DR, that will cut your render times incredibly. I assume you are using 2.0?
              3 second full res render... uh have your boss buy a time machine and go to 2030. Although RT is getting there. Watch this http://youtu.be/k1V8h7fsYmE?list=PL
                cuttingedge
                hi guys . This is my attempt to share a 100+ mb file of the model of the render i posted earlier. My files usually gets up to 180 MB.
                This renders in about 1 hour 15mins in my I7- 16gb ram using vray 1.49.
                I'd be glad to have somebody test out this model to see how renderers compare in terms of speed to deliver a decent 3000 render.
                This is with vray data but vray elements are in a layer which is turned off initially
                Check link below-- (hope the link works)
                File sharing and storage made simple
                (www.mediafire.com)
                Thanks in advance.
                Edd
                  cuttingedge
                  Im using still 1.49 in the office but will upgrade soon. Unfortunately Im the only SU users for now. All my colleagues are hardcore Max- Vray...
                  Yeah, Im sick of waiting that long..That sometimes mean staying overnight in the office. These is the era of RT, I know this shouldnt be happening...
                  • PixeroP Offline
                    Pixero
                    Here is a test render with Thea Presto AO. GPU + CPU.
                    I must admit I didn't put a lot of work on the materials.
                    I let it render for 39 minutes on my modest Macbook Pro laptop with a i7 and a Geforce GT 750m.
                    Resized from 3000pixels to 1600 to be able to post it.
                    Partial 3000 pixels wide render. Click to see it at 100%.
                    • andybotA Offline
                      andybot
                      I had some time to check out your scene. I was able to render at 1600 pixels in 5 minutes. Then with saving the LC and IRR maps, I ran a full res render in just under 10 minutes: http://www.mediafire.com/view/qqdk52aq9ff998z/full-res-test.jpg
                      There wasn't really anything I needed to do with the scene. I dropped in my own IES files since it wasn't included in your download. I deleted some high-poly stuff just to keep the parsing times down and help with scene navigation. For those things, I would typically use proxies, that way there's no speed hit at all.
                      My suggestion: get vfs 2.0 and use DR on as many machines as you can. ☀
                      Andy
                      • andybotA Offline
                        andybot
                        yeah, check your materials. You probably have things like semi-glossy reflection or refraction. Are those blinds 2-sided translucent or is it refractive material? Optimized, that should be a quick scene to do in vray. (prob 5 minutes on my hardware.. [[OK 15mins, conservative]] . I have 46 cores with DR...)
                          cuttingedge
                          Thank you guys so much for your time and effort to try my model. Those are fine renders.
                          From my side ,I happen to work with guys who do 3ds max and whose benchmark is Evermotion,
                          Honestly, I have to put in a lot to even try to match their results. VFSU 2.0 somehow is getting there. I have yet to see how Thea will perform.
                          @Pixero, 39 minutes may still be a little quite long for my boss, If we are to use GPU,
                          Then He would expect something like 3 - 5 minutes.
                          @Andybot, Yes Im immediately requesting an upgrade to 2.0 and as you say proxy the other hi poly stuff. your render is impressive for a 5 minute run, Is it done on one machine? Would I be able to cut that to say 2 minutes If I use DR on say 3 machines?
                          • andybotA Offline
                            andybot
                            5 mins. is with DR, (46 cores, around 3.5Ghz average). If it were on one machine only, probably 20-30 minutes for the 1600 pixel render.
                            to get down to 2 minutes - you'd probably need over 100 cores available (or else render smaller!)
                            • PixeroP Offline
                              Pixero
                              Thea Presto is much faster with a faster GPU than mine.
                              I know Solo has a Titan card.
                              Let's hope he gets time to do a test render to show what times are possible with it.
                              • soloS Offline
                                Will you send me the model as you have it set up already and i will test just GPU.
                                  cuttingedge
                                  i would really be thankful to see. titan is one solution im considering. 😄 even for my personal use. Might as well be convinced to learn Thea
                                  • soloS Offline
                                    I tweaked a few materials, ran Presto for 18 minutes only GPU (did not use CPU and GPU as I wanted to test Titan on it's own at low priority)
                                    3000x1875
                                    Device #0; GeForce GTX TITAN
                                    Building Environment... done. (0.648 seconds)
                                    - Polys; 564124, Objects; 1098, Parametric; 0
                                    - Moving; 0, Displaced; 0, Clipped; 0
                                    - Instances; 0, Portals; 0
                                    - Nodes; 165922, Leaves; 165908, Cache Level; Normal
                                    Device #0; memory ?/4095 Mb
                                    Device #0; 372x4 s/p
                                    Finished in 1115 seconds
                                    Finished in 18 minutes and 37 seconds!
                                    Funny how in Thea4SU my card shows 4GB ram and not 6GB, is that a Sketchup limitation?
                                    • PixeroP Offline
                                      Pixero
                                      It would be interesting to see how well CPU+GPU does.
                                        cuttingedge
                                        3000x1875
                                        Hi- res , clear, crispy image. At 18m 37 secs. That is impressive. Thanks for trying out.
                                        Now I'd like to consider Titan.. and probably Thea too.
                                        And I wish there's somebody who could tryout vray GPU . At least with these few infos, I can come up with a recommendation to my boss in terms of GPU hardwares
                                        Thanks a lot
