    Community Modeling
    52 Posts 15 Posters 12.0k Views 15 Watching
    • ely862meE
      ely862me
      Bit of work. Bumped the center of the roads, altered some sidewalks and the left building near the big crater .
      I believe it is time to partially demolish the right building near the crater and to add some garbage and demolition debris. It would be cool if someone want to model some soldiers, or at least one with several gears to wear.
      Elisei (sketchupper)
      Come and See EliseiDesign
      • soloS
        @tadema said:
        Pete, if your time allowed you above all would be more than welcome to join in.
        Bring the fun back into Sketchup πŸ˜›
        John
        Thanks for the offer, I believe you guys have this well taken care of, I doubt I could be of much help and besides I like watching what you do as I want to learn new tricks.
          Is there a file somewhere?
          Interesting idea for sure.
          • tademaT
            tadema
            Hello Rich, yes there's a file I've placed in a drop-box account, but I need to add peoples e-mail to allow them to take part. I don't know any other way of doing it.? It will also protect the model as it develops.
            Anyone wanting access let me know
            John
              Can you add me John? U got my email already I think?
              If not richob[at]sketchucation.com
              • soloS
                I'd like a stab at rendering the final model if possible
                • tademaT
                  tadema
                  You'd be welcome
                  John
                  • tademaT
                    tadema
                    There was just a couple of things I was wondering before it's too late.
                    What version of SU should the files be saved in.
                    There as 16 buildings visible atm (left to right) would it better if we had a "document" in the folder to let others know which part and who is working on what.
                    The Model needs sorting into Layers soon.
                    any other suggestions please
                    John
                    • DanielD
                      Daniel
                      When done, maybe it can be a "render-this" challenge
                      My avatar is an anachronism.
                      • ely862meE
                        ely862me
                        I think we can put some big numbers in front of them 1,2...n and anybody who wants to demolish them, should say it clearly and that would be his/her task.When the task is completed we should be able to move on.
                        The non intrusive objects: debris, soldiers, crates, guns, vehicles,bicycles,animals, etc, can be added by anyone with the condition they are on a separate group/component. The position of these wouldn't be fixed and they can be moved here and there to give the scene the most dramatic feel.
                        IMO
                        • tademaT
                          tadema
                          Updated Eli's last saved model:- added numbers 1-16 behind the buildings, Placed each building on a layer, removed the houses behind that are not seen, added a separate skp. file to the DB folder containing separate components, Saved the file in SU 6 at Lee's request.
                          will add a notepad so ppl can note down which building they are working on.
                          saved Skp. Community Model 02 - Updated 22 - 08 - 2014 PM Eli1
                          • Bryan KB
                            Please add my email.
                            See PM.
                            • Bryan KB
                              John, thanks. I received the notice and link, but when clicked it seems the page is not working. Do I also need to be member of Dropbox? (I'm not at present)
                              • tademaT
                                tadema
                                Hello Bryan, I've just googled and apparently you do also need an account, sorry I was unsure. Here's the state of play on the model
                                As you can see what remains is mainly damage to the buildings and a little "window dressing" to add. If it's easier I could e-mail you a file containing a building/buildings for you to work on then add it to the main model.
                                thanks
                                John
                                • olisheaO
                                  olishea
                                  this is excellent!
                                  oli
                                  • Bryan KB
                                    Thanks John. No problem. I'll sign up for an account. πŸ‘
                                    It's looking good!
                                    • olisheaO
                                      olishea
                                      I might model a gas mask if I have time, no promises.
                                      oli
                                      • KrisidiousK
                                        Krisidious
                                        Things in the model should have fredoscale applied to it to slightly bend and warp. Like the roof debris on the ground and the light post. The whole scene looks a bit too square. I know textures will hide it, but in real life the road would dip and roll ever so much. buildings would lean a bit here and there. Looking at the line up of modelers I've sure it will be spectacular.
                                        By: Kristoff Rand
                                        • ely862meE
                                          ely862me
                                          Hi Kriss, you are right. I did this partially for the things I worked on : the sidewalk near the crater, the fence on the left building near the crater, and the light post near the crater. The thing with the fredoscale is that all the component will become groups, therefor the file size will increase considerably.
                                          But wait a bit longer, we are still at the beginning !
                                          • tademaT
                                            tadema
                                            Thanks Oli, any "artefacts" to add to the scene would be good.
                                            Kriss, I was also thinking about Fredo-scale, it's good if not overdone or it can look a little cartoonish.
                                            John
                                            • 2 / 3
