    BugsplatRC resource DLL not found.
    renderpluginsextensions
    10 Posts 6 Posters 15.1k Views 6 Watching
      kayge25
      I am rendering a 42mb file model with bumps and displacement. Whenever i hit render button this what always happen. the bugsplatRC resource DLL not found. tried lowering my bumps and displacements and the output to 640x480. Still this happens. i am using Sketchup 2014 and Vray 2.0. need immediate help please. Thanks in Advance!
      • TedVitale_CGT Offline
        TedVitale_CG
        If you have displacement on to large a piece of geometry or a surface with very little segmentation Sketchup can run out of memory very quickly. You should try working with the 64bit workflow. This will help alleviate some of the problem you are running into. With out the scene to check however I cant really tell where the actual problem is. If the issue persists feel free to email support@chaosgroup.com
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          tahere
          I have the same error.please help me.
          what 64bit workflow?
          Does it mean that it is using 64-bit Windows?
            tahere
            I have the same error, please help me.i am using sketchup 2014 and vray2 on window 64bit.
              TedVitale_CG
              Try using the attached tutorial to render via the 64bit workflow.
              64-BitWorkflow.pdf
              Ted Vitale
                alaamadi
                hi, i have the same error but im using sketchup 2013,
                and i tried the 64bit-WorkFlow method , Thanks for trying to help anyway, but it didnt work
                i have another issue but not on the same pc saying "td_db_3.08_10.dll is missing error"
                any idea !!!!
                  TedVitale_CG
                  any idea !!!!
                  Please email your issue to support@chaosgroup.com
                  Ted Vitale
                    tahere
                    I worked by tutorial attached workflow 64 bit
                    but the rendering i recieved the same error(bugsplatrc dll not found)
                    please advise me on what to do.
                    thank you for your help.
                      Lummoxcz
                      Hi, I have the same problem - tutorial din´t help me.. 😞
                      • V Offline
                        valerostudio
                        Are you on 2015 64 bit SU? This should not be an issue any more if you are.
