VRay Image Size
Vray 2 (demo)
Sketchup 8 Pro
Windows 7I have recently started using Vray for sketchup and am having problems changing the output size. It seems to work on anything up to 400px but changing to anything larger does not have any effect. Any help would be greatly appreciated.
Is it limited in output size because you are using the demo instead of fully licensed version? That's common practice for demo software of that type.
Dave
Thank you for your prompt response. I am not sure, but it appears to be the case. However on a previous demo version (Vray 1.0) the output size was unlimited. Have also contacted Chaosgroup to see if they can offer a definitive answer.
V-Ray for SketchUp Demo Limitations
- Distributed Rendering limited to 2 render nodes
- produces watermarked images
- resolution up to 600x400
- rendered results limited to 4 lights
