    [Plugin] Stair Maker
    110 Posts 37 Posters 118.9k Views 37 Watching
    • TIGT Online
      I get this when pasting into the Ruby Console [in Model-Units=mm, in v2013 & v2014]:
      "9.84251968503937".to_l 0.38750077500155
      So it seems to work as a Ruby method [mm --> "]...
      Although the level of 'accuracy is somewhat extreme πŸ˜’
      So something else is adrift with the script itself πŸ˜•
        cboy1980
        Hey TIG / sdmitch
        So when deleting the 'Stair Maker.txt' I'm allways able to make 1 stair.
        When trying to make another one...
        same problem as before:
        Error: #<ArgumentError: Cannot convert "3.76640419947507" to Length>
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:267:in to_l' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:267:in get_defaults'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:77:in reset' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in `new'
        same problem different values
        • sdmitchS Offline
          sdmitch
          @cboy1980 said:
          Hey TIG / sdmitch
          I have made a few minor changes and have attached the plugin to a Personal Message. Please try it and let me know if there is any difference. Delete Stair Maker.txt file first.
          http://sdmitch.blogspot.com/
            GudmHr
            My Sketchup(2014) is configured to use decimal comma instead of point (the European way). If I make L-stairs/Open, everything works fine repeatedly. But if I make L-stairs/in-situ, some numbers are written to Stair Maker.txt with decimal points and Sketchup doesn't like that, so Stair Maker stops working. If I change those decimal points to decimal commas in Stair Maker.txt and save it, Stair Maker works again. I think this is the issue here: some internally calculated results are written to Stair Maker.txt with points instead of commas.
            • sdmitchS Offline
              sdmitch
              I know this is a problem for some but I have no way of duplicating it myself. Usually working in whole mm's is at least a partial solution. I will attempt a fix and send it to you by personal message.
              • sdmitchS Offline
                sdmitch
                GudmHr, Please check your personal messages for an attempted fix to the "," versus "." problem.
                  GudmHr
                  Thank you, sdmitch.
                  • bprzybytkowskiB Offline
                    bprzybytkowski
                    Hi.
                    I too am having the same problem using Stair Maker as posted above.
                    The error I am getting in Ruby Console:
                    Error: #<ArgumentError: Cannot convert "12.3031496062992" to Length>
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in to_l' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in get_defaults'
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:77:in reset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:68:in initialize'
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25:in new' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in call'
                    I'm working in EU comma separated units (e.g. 14,54m).
                    Is there any known solution to that problem?
                    • sdmitchS Offline
                      sdmitch
                      @bprzybytkowski said:
                      Hi.
                      I have sent you by PM the version that fixed GudmHr's problem. Hopefully it will do the same for you.
                        bprzybytkowski
                        The version you provided me by PM seems to be working without problem - thanks!
                        • architexA Offline
                          architex
                          how can i learn to work on this plugin?
                          i see the parameter window under my sketchup, but the result are blank.
                          • sdmitchS Offline
                            sdmitch
                            Maybe this old tutorial will be of some help.
                              db11
                              How tough is it to add an inside radius variable for the spiral stair generator to allow curved stair creation?
                              I'm trying to make a 180Β° curved staircase with and inside radius of about 3'.
                              • sdmitchS Offline
                                sdmitch
                                Something like this?
                                Spiral Stair.skp
                                  db11
                                  Exactly like that.
                                  It will be a single stringer (u-channel) open tread stair. I figured I could generate a follow-me path for the stringer chord pretty easily by simply joining the bottom centre points of the treads.
                                  • atelierpaarA Offline
                                    atelierpaar
                                    Hi there,
                                    after installing "StairMaker" the plugin shows up under "plugins"
                                    The Dialog box asks for "normal, spiral....." etc
                                    That was it, nothing else happens.
                                    Sorry - what has to be done next ?
                                    Thanks for your comments
                                    Uli
                                    • sdmitchS Offline
                                      sdmitch
                                      @atelierpaar said:
                                      Hi there,
                                      Uli
                                      This is what you should see
                                      If not, open the Ruby Console window(Windows>Ruby Console) and try the plugin again to see if there are any error messages.
                                        atelierpaar
                                        thanks for your quick response
                                        Here is what i get from the Ruby Console
                                        Error: #<ArgumentError: Cannot convert "7.65748031496063" to Length>
                                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in to_l' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in get_defaults'
                                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:77:in reset' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Hello Maker.rb:68:in initialize'
                                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in new' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in block in <top (required)>'
                                        SketchUp:1:in `call'
                                        • sdmitchS Offline
                                          sdmitch
                                          Do you use ',' instead of '.' between number and fractional part?
                                            atelierpaar
                                            Well, I dont get to type in any value.
                                            the plugin quits right after the first Dialog box
                                            • 5 / 6
