    [Plugin] Stair Maker
    110 Posts 37 Posters 128.7k Views 37 Watching
    • bprzybytkowskiB
      bprzybytkowski
      Hi.
      I too am having the same problem using Stair Maker as posted above.
      The error I am getting in Ruby Console:
      Error: #<ArgumentError: Cannot convert "12.3031496062992" to Length>
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in to_l' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in get_defaults'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:77:in reset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:68:in initialize'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25:in new' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in call'
      I'm working in EU comma separated units (e.g. 14,54m).
      Is there any known solution to that problem?
      • sdmitchS
        sdmitch
        @bprzybytkowski said:
        Hi.
        I have sent you by PM the version that fixed GudmHr's problem. Hopefully it will do the same for you.
        http://sdmitch.blogspot.com/
        • bprzybytkowskiB
          bprzybytkowski
          The version you provided me by PM seems to be working without problem - thanks!
          • architexA
            architex
            how can i learn to work on this plugin?
            i see the parameter window under my sketchup, but the result are blank.
            • sdmitchS
              sdmitch
              Maybe this old tutorial will be of some help.
                db11
                How tough is it to add an inside radius variable for the spiral stair generator to allow curved stair creation?
                I'm trying to make a 180° curved staircase with and inside radius of about 3'.
                • sdmitchS
                  sdmitch
                  Something like this?
                  Spiral Stair.skp
                    db11
                    Exactly like that.
                    It will be a single stringer (u-channel) open tread stair. I figured I could generate a follow-me path for the stringer chord pretty easily by simply joining the bottom centre points of the treads.
                    • atelierpaarA
                      atelierpaar
                      Hi there,
                      after installing "StairMaker" the plugin shows up under "plugins"
                      The Dialog box asks for "normal, spiral....." etc
                      That was it, nothing else happens.
                      Sorry - what has to be done next ?
                      Thanks for your comments
                      Uli
                      • sdmitchS
                        sdmitch
                        @atelierpaar said:
                        Hi there,
                        Uli
                        This is what you should see
                        If not, open the Ruby Console window(Windows>Ruby Console) and try the plugin again to see if there are any error messages.
                        • atelierpaarA
                          atelierpaar
                          thanks for your quick response
                          Here is what i get from the Ruby Console
                          Error: #<ArgumentError: Cannot convert "7.65748031496063" to Length>
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in to_l' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:267:in get_defaults'
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:77:in reset' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Hello Maker.rb:68:in initialize'
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in new' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Stair Maker.rb:25:in block in <top (required)>'
                          SketchUp:1:in `call'
                          • sdmitchS
                            sdmitch
                            Do you use ',' instead of '.' between number and fractional part?
                            • atelierpaarA
                              atelierpaar
                              Well, I dont get to type in any value.
                              the plugin quits right after the first Dialog box
                              • sdmitchS
                                sdmitch
                                That doesn't answer my question. If you could enter a number say 1234 mm as meters, would it be 1.234 or 1,234?
                                p.s.
                                Please check messages.
                                • F
                                  filipebonito
                                  hello,
                                  i have the same problem, when i open the plugin, i see the dialogue to chose the stair type, but after that get no options...
                                  i use "," in numbers, lile "12,50"
                                  here is the ruby console:
                                  "Error: #<ArgumentError: Cannot convert "4.921259842519685" to Length>
                                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:267:in to_l' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:267:in get_defaults'
                                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:77:in reset' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:68:in initialize'
                                  C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:25:in new' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Stair Maker.rb:25:in block in <top (required)>'
                                  SketchUp:1:in `call'"
                                  what can i do?
                                  thanks
                                  filipe bonito
                                  • sdmitchS
                                    sdmitch
                                    I have sent by Personal Message a version that should work for you.
                                      rabas
                                      Could i have , please, the comma version?
                                      • sdmitchS
                                        sdmitch
                                        I have updated the plugin at the Plugin Store to work with comma or period. Delete the existing Stair Maker.txt file.
                                          MattBram
                                          I meet the same result as Filipe does in the console, and the same result in Sketchup, i.e. nothing appears after having completed the tables.
                                          I tried using either "." and "," with the plugin download today, and I also tried working in inches as well as in mm without need of using decimals nor fraction.
                                          What have I been doing wrong?
                                          Thanks,
                                          Matt
                                          • sdmitchS
                                            sdmitch
                                            Deleting the existing StairMaker.txt file and allow the plugin to recreate it.
                                            • 5 / 6
