    [Plugin] Stair Maker
    110 Posts 37 Posters 128.7k Views 37 Watching
    • sdmitchS
      sdmitch
      @cboy1980 said:
      @sdmitch said:
      @luhrzeznik said:
      Hi, I'm having a bit of trouble here!
      I used the plugin once and it worked fine. But when I tried to use it again, it doesn't get past the Stair Type. I click my option and the screen just disappear and then nothing. Do you have any idea why that could be happening?
      I assume this happens regardless of which stair option is selected?
      Locate and delete the Stair Maker.txt file and try the plugin again.
      What Units system are you using, 1.00 or 1,00?
      I have the same problem here...
      Try to make a L-shaped stair... but after putting the measurements in the dialog box and clicking ok... nothing happens. The dialog box just dissapears. That's it. No stairs to see.
      Grtz
      cboy
      After clicking OK, you need to pick the model point to locate where the stairs are to originate. You should see a red "+" at the end of the mouse pointer.
      http://sdmitch.blogspot.com/
      • C
        cboy1980
        Grtz
        cboy
        Hey I still have no stair appearing... not even the red cross at the pointer.
        Even when clicking somewhere it does not happen.
        Grtz.
        cboy
        • sdmitchS
          sdmitch
          You may need to download a new copy since this plugin was recently modified to be 2014 compliant.
          Otherwise, open the Ruby Console window and execute the plugin to see what if any errors occur.
          • C
            cboy1980
            I checked with the ruby console...
            It mentioned the 'full acces problem' I tried to follow the steps given in the link by Tig but only got 1 stair then it stopped again. Also when changing the sketchup program to run under administrator, my orbitting with mouse did not work anymore... πŸ˜„ πŸ‘
            seems like I need to research further...
            • C
              cboy1980
              I still did not manage to get the plug in working...
              When changing my folder options (only read / full acces) sometimes I manage to get 1 stair... but after that it stops...
              ruby output:
              Error: #<ArgumentError: Cannot convert "9.84251968503937" to Length>
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:267:in to_l' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:267:in get_defaults'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:77:in reset' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in new' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:267:in call'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:120:in reset' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize'
                I get this when pasting into the Ruby Console [in Model-Units=mm, in v2013 & v2014]:
                "9.84251968503937".to_l 0.38750077500155
                So it seems to work as a Ruby method [mm --> "]...
                Although the level of 'accuracy is somewhat extreme πŸ˜’
                So something else is adrift with the script itself πŸ˜•
                • C
                  cboy1980
                  Hey TIG / sdmitch
                  So when deleting the 'Stair Maker.txt' I'm allways able to make 1 stair.
                  When trying to make another one...
                  same problem as before:
                  Error: #<ArgumentError: Cannot convert "3.76640419947507" to Length>
                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in `new'
                  same problem different values
                  • sdmitchS
                    sdmitch
                    @cboy1980 said:
                    Hey TIG / sdmitch
                    I have made a few minor changes and have attached the plugin to a Personal Message. Please try it and let me know if there is any difference. Delete Stair Maker.txt file first.
                    • G
                      GudmHr
                      My Sketchup(2014) is configured to use decimal comma instead of point (the European way). If I make L-stairs/Open, everything works fine repeatedly. But if I make L-stairs/in-situ, some numbers are written to Stair Maker.txt with decimal points and Sketchup doesn't like that, so Stair Maker stops working. If I change those decimal points to decimal commas in Stair Maker.txt and save it, Stair Maker works again. I think this is the issue here: some internally calculated results are written to Stair Maker.txt with points instead of commas.
                      • sdmitchS
                        sdmitch
                        I know this is a problem for some but I have no way of duplicating it myself. Usually working in whole mm's is at least a partial solution. I will attempt a fix and send it to you by personal message.
                        • sdmitchS
                          sdmitch
                          GudmHr, Please check your personal messages for an attempted fix to the "," versus "." problem.
                          • G
                            GudmHr
                            Thank you, sdmitch.
                            • bprzybytkowskiB
                              bprzybytkowski
                              Hi.
                              I too am having the same problem using Stair Maker as posted above.
                              The error I am getting in Ruby Console:
                              Error: #<ArgumentError: Cannot convert "12.3031496062992" to Length>
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in to_l' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in get_defaults'
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:77:in reset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:68:in initialize'
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25:in new' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:25 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Stair Maker.rb:267:in call'
                              I'm working in EU comma separated units (e.g. 14,54m).
                              Is there any known solution to that problem?
                              • sdmitchS
                                sdmitch
                                @bprzybytkowski said:
                                Hi.
                                I have sent you by PM the version that fixed GudmHr's problem. Hopefully it will do the same for you.
                                • bprzybytkowskiB
                                  bprzybytkowski
                                  The version you provided me by PM seems to be working without problem - thanks!
                                  • architexA
                                    architex
                                    how can i learn to work on this plugin?
                                    i see the parameter window under my sketchup, but the result are blank.
                                    • sdmitchS
                                      sdmitch
                                      Maybe this old tutorial will be of some help.
                                        db11
                                        How tough is it to add an inside radius variable for the spiral stair generator to allow curved stair creation?
                                        I'm trying to make a 180Β° curved staircase with and inside radius of about 3'.
                                        • sdmitchS
                                          sdmitch
                                          Something like this?
                                          Spiral Stair.skp
                                            db11
                                            Exactly like that.
                                            It will be a single stringer (u-channel) open tread stair. I figured I could generate a follow-me path for the stringer chord pretty easily by simply joining the bottom centre points of the treads.
                                            • 5 / 6
