    Housebuilder
    160 Posts 57 Posters 246.8k Views 57 Watching
    • C
      ckizer
      There is no-where to get the plugin anymore. The official website has been offline for some time. I heard about this plugin and really needed it. I found these forums. Unfortunately the only version hosted here that worked is metric version.
      I'm trying to design a house in the US, so this won't work. Can someone please post a copy or the copy they have of the US version? I have the one where you can modify the file to put any sizes you want, but it's metric only.
      • cottyC
        cotty
        @davelukasek said:
        Perhaps you could simply provide me a link to the correct place to download it. Thanks.
        one suggestion: 9 post above your question πŸ˜‰
        my SketchUp gallery
          @davelukasek said:
          I got the plugin from a link in a review somewhere. The extension warehouse which is part of SU 2014 does not find it.
          The Extension Warehouse host a lot of plugins and extensions but not all of them.
          I would have done so but I made the apparently false assumption you'd actually read this thread before posting. So here you go: http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=56772%26amp;p=533150#p519203
            And then the post after that where I attached a fixed metric version !
            http://sketchucation.com/forums/viewtopic.php?p=519210#p519210
              davelukasek
              I did read the thread, but the link in that post goes to a dead web page. I made the false assumption that you'd actually give me a working link.
                You are mistaken - that link opens the post a few above this one... πŸ˜•
                The one above that contains my fixed metric version...
                This link go directly to my post...
                If it's still not working for you, the how are you using it?
                A left click moves to the post, a middle click opens it in a new tab... πŸ€“
                • C
                  ckizer
                  For anyone needing good links. Just put it in your plugins.
                  METRIC :
                  http://cl.ly/2s0m063u2f0m
                  IMPERIAL (North America):
                  Doesn't exist?
                  I'm not sure if you guys are talking to me or dave? It's obvious most of the people posting have a good working copy of the imperial version. Would be wonderful if you could take 30 seconds to share. Metric is the only version I can find, and that's not useful in the US for design.
                  I'm planning out a little tiny house build in a few weeks and want to estimate the 2x4 I will need πŸ˜„
                  • X
                    xeno456
                    After downloading the zip and renaming to .rbz it only opens the file but nothing to load. Any suggestions?
                    Thanks,
                    Clint
                    PC, Win8, SU14
                      davelukasek
                      "This link" that you refer to in your post appears, at least, to link to the METRIC version. Perhaps I was unclear, I need the Imperial version. ckizer seems also to be unable to get to the Imperial version.
                        @davelukasek said:
                        I did give you a working link. πŸ˜’ The link in the post I sent you to is not a dead web page as you assert. It takes you to this page where there is a handy "Download" button clearly visible. This is for the imperial version of the extension.
                        HouseBuilder_extension.zip
                          Doesn't exist?
                          You keep writing that but it isn't true. It does exist.
                          Imperial version installed on Mac, today, from the file I downloaded from the link that was provided earlier in this thread.
                            The original imperial version installs and works in all versions including v2014.
                            If you meant that it didn't appear in the Plugins menu after it was installed/loaded - if you read its notes carefully then you'd see that its submenu item is under the 'Draw' menu !...
                            Alternatively, perhaps activating its Toolbar, so that you can run more easily it from there, would resolve your apparent issues...
                            • C
                              ckizer
                              Guys I'm not sure if you aren't understanding. Link me to the file. I've seen all those other threads referenced here and none of them have a working link to the download of the imperial version. You keep telling me how to install the plugin which is the easiest part. The part I need is a zip file of housebuilder for imperial. Both of the threads you keep linking to have 404 errors when you go to click the link to download the plugins. Surely it wouldn't take more than 30 seconds to repost the plugin you already have?
                              What am I missing?
                                Seriously? πŸ˜’
                                How can we make this any easier for you?
                                404 Not Found
                                (sketchucation.com)
                                The screen shot I posted today was made a few minutes before I attached it. I didn't get a 404 error when I followed the link. Box followed it today, too. He didn't get a 404 error, either. Something must be wrong on your end.
                                • BoxB
                                  I have downloaded and installed from the original link in my original post which dave has linked to and downloaded from.
                                  It installs and works perfectly in imperial.
                                  Perhaps you need to change the units of your model.
                                    Funny. I'm in the US. πŸ˜’
                                    I downloaded the file today, in the US, about 5 hours ago. The page worked fine, then. It worked fine again when I went back to it to make the screen shot.
                                    Did you finally download the file I posted? πŸ˜’
                                    • C
                                      ckizer
                                      Ruby Library Depot Website has NOT been working for multiple days anywhere in the US. You might be able to visit that page but that french URL is not available to anyone inside of the US. Specifically California comcast.
                                      Specifically until this exact moment you told me to try right now this morning did it work. It still wasn't working 3 hours ago. But right now it's up.
                                      Thank you. I was very familiar with that link, it just wasn't working on any comcast/us computers and multiple people on youtube sketchup channels and forums have been asking why the site was down since June 20th 2014
                                      • C
                                        ckizer
                                        I was able to get the files just now off ruby depot. It still doesn't resolve to my friends in New York on Time Warner. It looks like that website had downtime and several edits to their DNS entries. Potentially DNS wasn't setup correctly? (Network Datacenter Admin here) πŸ˜„
                                        I had all the links, and such they just weren't working πŸ˜„ now they are. Downloading and mirroring them for all πŸ˜„
                                          So in other words, we've been wasting our time attaching the ZIP file and such. I'll remove it then. πŸ˜’
                                          • C
                                            ckizer
                                            Dave R:
                                            Thanks for being patient. It's working now. I think that's why the other person was having trouble. For anyone who needs the imperial version but can't get it from Ruby Depot: LINK http://cl.ly/0L0y1A100344
                                            • 2 / 8
