    Photo import / beginner
    4 Posts 3 Posters 264 Views 3 Watching
      kojack666
      Using sketchup to build a 3D model of my home plus gardens.Done the house structure and am trying to import a photo texture for my front door onto the face I've selected, but it will not allow me to. Has that wee no can do symbol on the image import. I can place the same image on any other face , but not the one I want.
      If I put a block colour in the face it is graduated.
      please helppp!
      • mitcorbM Offline
        mitcorb
        Hi:
        Did you refer to this article?
        http://help.sketchup.com/en/article/167479
        The article was found by Help>Knowledge Center> type keyword "photo" in search box and after a little wading, find that article.
        There are You Tube videos on the subject, also.
          kojack666
          Thanks for the response.
          Yes I know about this method of importing an image, and this is what I've been doing. This works on all the faces on the file I'm working on , except one particular face.
          I suspect it could be that I grouped the the house building and it is the door image that will not apply.Ive tried ungrouping but it still has not worked.
            Apply textured images onto the face itself, not the group/component.
            Edit the group to get into its geometry...
            Plain materials applied directly onto a 'container' work fine as no UVmapping is needed, but to get good results apply textured materials onto faces, you can then edit the placement etc in the context-menu item 'Texture'...
